Electrical Supplies Logo
Patrick Sorrentino Posted on May 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BUFFALO TOOLS 2000 WATT GENERATOR 12 VOLT OUTPUT BUT NO AMPS WILL NOT EVEN LIGHT A 12 VOLT TEST LIGHT BUT VOLT METER READS 12 V.D.C. WHAT IS WRONG ? PLEASE HELP.LABEL SAYS FOR 12 VOLT BATTERY CHARGING
"THERE IS NO VOLTAGE REGULATOR ON THIS MODEL ONLY A DC RECTIFIER. THE TWO WIRES COME OFF THE FIELD AND GO RIGHT TO THE RECTIFIER THEN TO THE TEN AMP CIRCUIT BREAKER THEN TO THE OUTPUT, THAT"S IT."
Bill Boyd
Level 3:
Top Expert:
  • Buffalo Tools Master 53,816 Answers
  • Posted on May 07, 2016
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11934262
Points
172802
Have the voltage regulator system checked
in the regulator the voltage controls the amperage allowed and it that unit is not working properly then there will be no current out put
that regulator could be part of the control board for the main ac out put and may have developed a fault in the section for 12 volts on the board
there is a limit on the charge rate for the battery and if it is exceed it may have damaged that circuit or possible blown a fuse in the amperage circuit
Testimonial: "THERE IS NO VOLTAGE REGULATOR ON THIS MODEL ONLY A DC RECTIFIER. THE TWO WIRES COME OFF THE FIELD AND GO RIGHT TO THE RECTIFIER THEN TO THE TEN AMP CIRCUIT BREAKER THEN TO THE OUTPUT, THAT"S IT."
  • Bill Boyd May 08, 2016
    current(amps) is controlled by the voltage allowed through the field windings so it seems strange that the windings are connected directly to the dc outlet through the rectifier diodes with out some for of current control or voltage control
    May be if you talk with a gen set repair shop and get some idea of what is possibly wrong so that no current is flowing ( possible burnt out circuit breaker producing too much resistance
    I as yet not been able to source a schematic diagram but I have found that the set is a GEN 154 unit
1helpful
2answers
Why wont a coleman model 58022 solar panel power a 12 volt test light
P/V=A
The panel is rated 6 watts at 12 volts 12 / 6 = 0.5 Amps
So in full sun the panel "should" produce 1/2 Amp at 12 Volts.
What type of 12V bulb and what is its current rating?
1helpful
Have a 4000 watt sportsman generator that will not produce electric i have replaced the avr what next
Could be lost exciter current. This is how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With generator running, insert bare ends of wires into AC outlet - one to Hot, the other to Neutral. Insert and remove quickly. There should be a flash and power will be restored. If not, repeat until you get that flash and output current restored. Using light gauge wires is so that if you are too slow to remove them once AC is restored. they will burn out before the battery suffers from the AC incoming. Be quick and be careful.
Hi, I recently purchased a used makita 6100r generator and when checking it out I discovered on my 30 amp 220 receptacles arent getting full power. I took out the receptacle and checked the wires in back...
You may be asking too much of the unit; the 5800 watts a which it is spec'd, may be a 'peak' power rating which may be 15-20% higher than its continuous rating. 30 Amps at 220 volts implies 6600 watts which is higher than even the peak power rating. I would expect the unit to produce ~4800 watts continuous or around 22 Amps.
Decided to check my statements and found this, which I quote:
Generator Volts AC (60Hz) 120/240 Max. Output Current 5800W-48.3A/24.2A Rated Output Current 4800W-40A/20A Volts DC (AMPS) 12 (8.3)
1980 sportster not charging. battery is new and connections all seem good.. tested generator output at battery and it shows no increase at all while running.wondering if the problem is the regulator or the...
To find out which is bad, you have to check the maximum output of the generator. To do this, you'll need a good voltmeter and a jumper wire. First, remove both "A" and "F" terminal wires. One of the wires is a hot wire so don't let it short to the frame. Then set your meter's function switch to DC VOLTS with a range of 50 volts or greater. Connect the positive meter lead to the "A" terminal and the negative meter lead to an engine ground. Start the engine and run it at about 2000 RPM. MOMENTARILY connect a jumper lead from the engine ground to the "F" terminal. Your volt meter should read 25 to 30 volts. If not, polarize the generator but MOMENTARILY shorting the battery positive post with the "A" terminal and recheck the maximum output test. If you do not have at least 25 volts out of the generator, you need to service the generator. If you do have 25 or more volts from the generator, your regulator is probably bad.
good luck
Steve
3helpful
Not charging
To test the chargeing system on your bike. First, text the battery. Unless it is "brand new" there is always the posibility that your battery is the problem. This is especially true on an Ironhead Sporty due to the vibration. Take it to an automotive parts store and ask them to load test it.
The first thing we want to do is to "polarize" the generator. Using a jumper wire, MOMENTARILY touch the wire from the "A" terminal to the positive terminal of the battery. Just make it spark, that's all.
Now, with the battery FULLY CHARGED, connect a DVOM (digital volt ohm meter) to the battery. Red meter lead to the positive and black meter lead to the negative. Put the meter's function switch in DC VOLTS, 20 VOLTS or greater scale. Start the engine bring it to a high idle. The meter should read 14.5 to 15.0 volts. If not, test the generator.
First, remove all the wires from both the "A" and the "F" terminals. put your meter's function switch to DC VOLTS, 50 VOLTS or greater. Connect the red meter lead to the "A" terminal and the black meter lead to a good ground. Start the engine and bring the revs up to about 2000 rpm. MOMENTARILY, connect a jumper lead form ground to the "F" terminal of the generator. Your volt meter should read 25-30 volts.
If your generator output is good, you need to replace your regulator. If the output of the generator is zero or low, you need to service the generator. Check the brushes to make sure they're not worn and you may need to recondition the communtator surfaces.
Good luck
steve
Buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
1helpful
My Generator is putting out voltage on both the neutral side and positive side of 110 Volt recepticles. When hooking a meter to both sides (Neutral & Positive) it is showing 184 volts! It burnt up a...
Check the voltage with a meter in all the recepticles with your meter leads in the left and right slots on the plugs. Is that 184 volts AC there? If so, your gen has big problems with the voltage regulator. Let me know what you read. You can check the right slot of each plug to the round ground hole on the plug too, should be 120 volts there.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
2answers
Battery Light keeps coming on in my 1997 Windstar
Most likely there is a bad diode in the alternator. needs tested.
Gererator wont put out any volts
Do a ohm test on armature slip rings with brushes removed.You should have continuity between rings but not between either ring and shaft.
Top Buffalo Tools Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
