The Original Thermostat Made a loud Bang and wire melted. I replaced the Thermostat but then still no heat. I figured the element blew. so I have replaced the element and now it warms but the fuse blows within 60 seconds. could this be a faulty thermostat??
SOURCE: The bottom (fan oven) of my Neff U1721 made soft
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
SOURCE: My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
SOURCE: Hi - have a Neff U1721 double oven, the element in
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
