Plumbing Logo
Judy Asplund Posted on May 06, 2016
Where is the brand name printed on a kohler kitchen faucet
russlakeside
Level 1:
  • Contributor 37 Answers
  • Posted on Oct 08, 2018
russlakeside
Contributor
Level 1:
Answers
37
Questions
0
Helped
15749
Points
88
Dave Da Plumber
Level 1:
Habit-Forming:
  • Contributor 38 Answers
 Dave Da Plumber
Contributor
Level 1:
Habit-Forming:
Answers
38
Questions
Helped
26900
Points
45
There is normally a tag on one of the supply lines.
5 Related Answers
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 26, 2009
SOURCE: kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
defadad
Harry Goodwin
  • 353 Answers
  • Posted on May 07, 2009
SOURCE: Single Handle faucet broke on my Kohler kitchen
Is cheaper to replace the whole tap as the service kits cost almost as much as the tap to buy, I presume you are talking about a flick mixer tap (that is what they are called in australia)
Replacing them is reasonably easy, turn off water at the main out on the footpath turn the tap on to let the water run out, go under the sink with a couple of spanners or deep reach socket and undo the lines and the tap hold down nuts and remove, replace in reverse order
cheetohman
  • 21 Answers
  • Posted on Nov 16, 2009
SOURCE: kohler forte single control kitchen, low colder water pressure
1. If it is old enough, it is time to replace the control cartridge.
2. Check your supply stops under the counter, check that they are both supplying full pressure.
Anonymous
  • 8197 Answers
  • Posted on Mar 19, 2010
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
80stech
  • 120 Answers
  • Posted on Apr 19, 2010
SOURCE: I had a dripping Kohler Finial kitchen faucet
Any bit of dirt or grit in the line will get caught in the cartridge if not flushed properly.
1helpful
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
Replacing hose on a Kohler model numbe K- 10433
http://411plumb.com/kohler-forte-faucet-troubleshooting-repair-guide/
2helpful
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Brand new kohler cruette. attached cold and hot water fine. when snapping in the pull out faucet hose it sprays all over under the sink
Hi rysenga, the problem is an omission of directions. The section 9 directions are the worst offender and left me never again to purchase a Kohler product. First, this connection for the pull out hose to the outlet fitting should have been a screw on connection. Should have been. Ok it was not, I'll get over it. But the directions never mention having to install the white plastic bushing. Not at all. Nor does it mention that the bushing should be put on the outlet first and then push the hose connection in. This omission is a huge one, but should help anyone else reading this complete the install. Find the oval lip white bushing and install this first on the body, and then just push the connector in. Done.
1helpful
Kohler forte single control kitchen, low colder water pressure
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
