Question about SVP Aqua 5500 18mp Underwater Digital Cameravideo W/dual Lcd Screens Waterproof
How do I get battery cove open?
I push the bent arrow..but door does not open.
    Top Expert:
  • SVP Master
  • 29,139 Answers
Seems like others have the same problem. Push and hold the latch and then slide the cover outwards.
There is a video here
https://www.youtube.com/watch?v=yVPLsCZr8Pc
SVP Aqua 5500 How to open battery compartment for SVP Underwater Camera
Posted on May 05, 2016
SOURCE:
B&d control a door mpc2 model not opening control panel has flashing green up down light and also flashing red light limit set
Check your user guide if available. It sounds like you haven't set the door open limit, so press the up arrow & fully open to the door & push set, do the same for the down arrow until door is completely closed. Push the set button again & the door should be right..
Apr 19, 2016 | Building Materials
How do I change the batteries?
most digital cameras have a battery door with a arrow mark and open symbol, push/pull in the direction of the arrow,
Jun 02, 2015 | Cameras
Door panel removal
first remove the handle cover two cove . the small one with s.w if electric power window . or same cove use screw driver . second step move big cove to front side it will remove easy . two bolt in side with screw drive .then remove small cove( side mirror handle cove ) near door opener . small bolt inside .then 3 bolt under the panel
the force the clips out
Dec 29, 2012 | 2005 Skoda Fabia 1.9
How do I get the battery compartment open on the Leapster GS Explorer?
To open the battery compartments firmly press down on the arrows with your thumbs and push it out. You should feel the cover unlatching as you firmly press down and out.
Dec 02, 2012 | LeapFrog Leapster Explorer Learning...
Cannot open case to install batteries. Pushing door in direction of arrow. Is there something else?
I was able to get it open by putting my finger on the battery door back toward the screw and pushing it down and forward until it popped open. I worked for hours trying to get it open. I found a video on uTube that gave an opening review of the camera and I saw how he opened it. Hope this helps.
May 25, 2012 | Vivitar ViviCam 7122 Digital Camera Blue...
Wher do the bateries go in the coolpix L20 camra?
There's a door on the bottom of the camera, marked "CARD" and "BATTERY". Slide the plastic latch toward the back of the camera and then slide the door to the outside (there's a bent arrow marked on the door as well). With the door open, the battery well should be obvious. The battery polarity is clearly marked.
Dec 01, 2010 | Nikon COOLPIX L20 Digital Camera
N70 is not oppend
If you want to open it, just press on the downside rectangle shaped thing on back and slide the back cover down.You can see the battery and all.To open the front cove, hold the phone upside down and backside facing you.Move the edges to both sidesand push the cover to front
Aug 25, 2009 | Nokia 6600
Cannot open battery case
Put your thumb on the cover, push it toward the back of the camera and then toward the near end of the camera, and then it will swing open. The directions are indicated on the bent arrow on the cover.
See the illustrations in the "Insert the Batteries" section of the manual (page 12 in my copy).
Jan 16, 2009 | Nikon COOLPIX L18 Digital Camera
Fuel door wont stay closed
there is a little metal tesion bar/bracket that keeps it in the open or closed position. If your fuel door itself is not bent or damaged then I would check this bar to see if it has been bent or out of place. I'm not sure if there is a replacement part; I just bent mine a little to get it to stay closed. Unfortunatly I left it open the other day when I went thru a car was after fueling and the door is bent now so I have another issue to deal with.
hope that helps
Nov 12, 2008 | 1997 BMW 328
SVP Aqua 5500 18mp Underwater Digital Cameravideo W/dual Lcd Screens Waterproof Logo
179 people viewed this question
Top SVP Video Cameras Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Vladimir Frolov
Are you a SVP Video Camera Expert? Answer questions, earn points and help others
