Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
Lynda Stahl Posted on May 05, 2016
How do I change the outgoing message for the answering machine?
My granddaughter was playing with the phone and changed the message.... I don't know how she did it and how to change it back
How do I change my outgoing message
I need the phone Model # ? You can go online and google the phone and how to get through the menu options.
tip
Remote access for machine
This come from a previous model than I have (mine is a ol5870), but seems to work for this one in retrieving messages from another phone.
Default access code is 0000 if you haven't changed it (but you should); when answering machine answer dial in the 4 digit code while the outgoing message is playing.
Once in dial 1,2, or 3 to play messages (mail box number I believe)
You can dial * for a help menu
4 Repeat a message
44 Ignores a message (message won't remote retrieve next call)
6 plays next message (skip to next)
7 Deletes message
8 Lets you record a memo
9 Let's you change the outgoing message (5 stops the recording)
0 Toggles answer on/off
I hope this helps some people at least in part.
Uniden phone change message
http://wiki.answers.com/Q/How_do_you_record_an_outgoing_message_on_your_uniden_6.0_DECT_The_instructions_say_to_select_command_8_on_the_menu_How_do_you_get_to_command_8
I want to change the greeting on my outgoing voicemail and cannot remember how to do so? I know I pushed a particular button and held it but it's been years since I've needed to change.
The TGA-101S isn't an answering machine, and thus doesn't have an outgoing message. Please consult the documentation for your answering machine, or else repost your question specifying the make and model of the answering machine.
1helpful
I need to know how to retrieve my messages when not home. I have the Southwestern Bell Freedom Answering Machine Model No. FA 972. Thank you.
Call your phone, let the outgoing message play when the machine answers, and wait for the beep. After the beep, enter the 3-digit security code you'll find on a sticker on the bottom of the machine. The machine will beep twice to let you know you entered the right code and it's ready for your commands.
Remote commands:
1# Plays messages in mailbox 1
2# Plays messages in mailbox 2
3# Deletes old messages (you need to play them all back first)
7# Starts recording a new outgoing message (press 7# again to stop recording)
9# Turn the system on or off
0# Monitor the room
While you're playing messages (you pressed either 1# or 2#) you have these commands:
3# Erase current message
6# Repeat previous message
7# Skip to next message
8# Repeat current message
## Stop playback
After your messages have played, you have 20 seconds to enter another command before the machine disconnects automatically.
You can download the manual here so you'll have a copy for future reference.
THERE IS AN A ON THE DISPLAY
Your answering machine is in announce mode, where it plays an outgoing announcement but will not record any messages. To change it, press MENU until the system announces "Set announce only." Press CHANGE until the system announces "Off."
The above is from page 28 of the manual.
How to reprogram the outgoing message on an answering machine
I have an answermate 62255 but mine is labeled Bell. Open
the casette compartment. There is a button labeled ogm. Hold
down until the unit beeps. Record your message and press stop
when finished. It will play your message back. Repeat until you
are satisfied
2answers
I wish to create my own message on the answer-phone.
The easiest way to gain access into an answering machine is to use it's preset access code. This is the access code set at default by the vendor on the given device. The best thing about this is that most users don't bother to change the access code to their device, if they even know that they have such a feature. Even worse yet, some of the manuals given for the device by it's vendor even tells the user that changing the access code is optional, not necessary. So of course since most people only do what they feel is necessary, these access codes are many times if not usually set at default. So what I'm going to do for you now is list the different popular vendors out there, and include their preset access codes, how to use them, and controls to use after gaining access. Keep in mind that if there is no model number beside the vendor, then that means that the information given works on most of their models. Likewise of course if there is a model identification beside the vendor name (placed in parenthesis) then that of course means that the information provided is model dependant. So let's begin, shall we?
1) AT&T - preset access code is 10 - when the answering machine picks up punch in the access code
7 - play messages
6 - play new messages
# - stop/pause
2 - repeat message
5 - skip message
4* - record announcement (push # to end recording)
41 - play announcement
* - record memo
33 - delete all messages
3 - delete selected
0 - turn system on
88 - turn system off
99 - change remote code
2) BellSouth - preset access code is 555, Mailbox 1: 555, 2: 666, 3: 777, 4: 888 - when the machine picks up hit * and then punch in the access code
0 - help (use this to get the commands available)
3) Freestyle - preset access code is 000 - when the machine picks up push in the D button and then punch in the access code
2 - play all messages
3 - play new messages
4 - skip back during messages
5 - delete during messages
6 - skip forward during messages
8 - play outgoing message
9 - record new outgoing message
0 - set answering machine on/off
1 - hear main menu
4) Vtech (VT650) - preset access code is 0000 - enter access code during announcement
#4 - repeat message
#5 - pause message
#6 - skip to next message
#7 - delete message
#8 - skip backwards
#9 - stop/exit any function
*8 - room monitor
5) Vtech (VT2650/VT2468) - preset access code is 50 - enter access code during announcement
#4 - repeat message
#6 - skips message
#5 - stops
#9 - delete message
#7 - review announcement (after beep press 7 to record an announcement and use #5 to stop)
6) Vtech (HK5886) - preset access code is 48 - enter access code during announcement
#1,2,3 - play new or old messages
#4 - repeat message
#6 - skip message
#5 - stop
#9 - delete message
7) Olympia (OL2410) - preset access code is 0000 - enter access code during accouncement
1,2,3 - select and play messages
4 - repeat message
44 - ignore message
6 - play next message
7 - delete current message
8 - record memo
9 - record announce (5 to stop)
0 - toggle answer on/off
* - play help menu
8) Doro - preset access code is 321 - enter access code right after outgoing message has played (or during)
1 - repeat/skip to previous message
2 - play/pause message
3 - skip to next message
4 - play current outgoing message
5 - record new outgoing message
6 - stop
7 - erase current message
8 - switch off answering machine
9 - switch on answering machine/select outgoing message
0 - (after playback) erases all messages
# - end playback
## - end call
9) Virgin Pulse cordless phone - preset access code is 123 - enter access code during outgoing message
1 - review current message
2 - skip to next message
3 - erase the current message
4 - play all or new messages
7 - repeat voice menu
0 - turn on/off TAD
10) Panasonic - preset access code is 11 or 1111 - enter access code during outgoing message
4 - new message playback
5 - all message playback
1 - repeat
2 - skip
9 - stop
7 - record new announcement (use 9 to end recording)
There are also a few random vendors that don't automatically preset an access code on the machine, forcing it's user to set one up him/herself. This is a small step forward as far as security is concerned, but every vendor I saw that did this still used a mere 2-digit access code. To test and see if your target has this type of setup press # when the machine start, and then press 0. If the machine returns to the annoucement then you know this is the kind of machine it is. Of course, in reality, this isn't all that bad of a scheme since you have 100 different combinations available for the access code. However, most users simply set these access codes as 11, 22, 69, etc. So yeah, just try it out. If it disconnects you after so many tries, call back from another payphone (which you should be using in this case).
Thanks for contacting Fixya
Jun 17, 2009 • Cell Phones
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
RCA 25205 2-line corded pnone answering machine won't answer
Record the message for both line one and line 2, see if that helps.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
