Archos 405 Digital Media Player Logo
A
Anonymous Posted on May 05, 2016
How can i delete some of my music from this device
How to remove songs
Music can be deleted from your Kindle Fire by pressing and holding the title from the Device tab and selecting Remove Album/Song from device. Tap Yes to confirm you'd like to delete the song or album from your device.
Music stored in Your Music Library cannot be deleted through the device. To delete music stored in your Your Music Library, visit www.amazon.com/musiclibrary.
How do i delete music from my pyrus mp3
Some devices require going on a computer and deleting music. If you can't find the "delete" in the settings on the mp3 player, then go on a computer and delete from there.
5answers
How do i delete songs from an Iphone 3gs
1.Go to Settings
2. Go to General
3. Go to Usage
4. Wait for Storage to load
5. Go to Music and swipe
6. Delete will pop up
7. Press Delete
This will delete ALL songs, but will not remove the music app.
There you go.
How to Delete Songs from iPhone
iPhone Data Eraser Clean up Data Safeguard for Ultimate Privacy...
3answers
Deleting songs , how do you delete songs off the ipod touch?
connect it to itunes.. click on the ipod and under the music tab.. uncheck sync all music from music library
Unable to delete installed music.
refresh as much as you can. it doesn't readily delete or refresh sometimes.. you have to try it until you delete the file..
Sansa m230 cannot see previously installed music files now that WMP11 is installed
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
I can delete music from my MP3
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs1.gif - accesories - windows5.gif explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync2.gif panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Thank You
Computerrep
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
How do you delete music files?
You can manually delete music thru My Computer>Device Name>Music Folder. If you are using Windows Media Player, on the left side you can click on the device name>music and delete them there. You can add to this question for further assistance. Best of Luck.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
