it sounds like there's a block somewhere in the system,unplug it,get a shop vac and a brush,vac up all the lint you can see then set the shop vac up to blow and blow all the lint off of the motor,out of the gas tube where the ignitor is and then clean out the duct that the lint filter slides into,pull the vent line off of the back of the dryer and start it and see if that makes a difference,also on the blower wheel housing there's a cycling thermostat part number 37001136
that could be bad or if you use cling free sheets the back of the t-stat could be covered with the white powder from the sheets and lint,you can try cleaning the back of it off but it sounds like you have a block somewhere,if the dryer does run good after you clean it out and run it with the vent line off the block most likely is in the vent line,if it's a long run stick a leaf blower into the vent line and blow all the lint out of it to the outside,make sure there isn't a cage or anything outside that's blocking the vent.i know you say it's clear but check it again before you start changing parts it sounds like bad air movement.good luck and if possible let me know what you find.
