you will need to contact topcon this is a very bespoke item and its unlikley other drivers or sync tools will work and the link software may need to be licensed
It's likely leveled past it's leveling limit. You can try pulling out the 4 screws holding the bottom out, and very carefully opening the bottom of the laser. The main circuit board is attached to the base, so do not pull apart hard or too far. Next mark all the connectors on the board, and what wires go to them, and pull them all out. Remove the bottom completely and you should see the leveling assembly. Move the gears so the leveling system is more centered. Put it back together and test. If it doesn't work then you have something mechanically out of alignment or electronic values have messed up, and you have have to bring it somewhere for repair.
