Also tried another generic remote; programmed it for Panasonic TV only the power button would work on it too. None of the vol, ch, and AV button would work.
Try replacing the remote controller, because the keys on the remote gets damaged due to moisture or dust, the buttons on the tv set may not work at all.because the contact plates on the push button may get damaged..
please replace the remote controller with new one to make sure the problem with your tv set before repairing complex circuit boards.
If the buttons on the TV -and- the buttons on the remote don't work, then there's definitely something wonky with the TV.
The good news is that the power works and the picture looks good. That rules out a bunch of things. If you don't mind tinkering, replacing circuit boards on TVs is pretty straight-forward -- just take off the back, unscrew the offending board and replace it. You'll have to do a little research to narrow down to the right board to replace -- it might be this key controller board:
http://www.shopjimmy.com/panasonic-tnpa4280s-gs-board.htm
TRY UNPLUGGING THE TV FOR 15 MINS THEN RETRY
