Dishwashers Logo
edel connolly Posted on May 03, 2016
Hi my dishwasher is showing h4/5/6, wht does this mean please?
Palota P
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 03, 2016
Palota P
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3360
Points
5
Check this link here
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3714-beko-electronic-dishwasher-fault-codes
H4/5/6 pretty sure it means errors H4, H5, and H6 hope this helps
On my Siemens dishwasher there is an arrow pointing right to a vertical line. Dishwasher doesnt work. Please help!
The varioSpeed symbol means the running time is shortened depending on the washing program.
Do you see an error code displayed - Siemens dishwasher error codes inform you that there's a problem with your machine. Please have look here
https://www.siemens-home.bsh-group.in/customer-service/support/problems/dishcare/dishcare-error-codes
Hope this helps.
Best,
Dave, Just Fixed
Hi I have a Miele G 5100 SC dishwasher on the digital display it shows 0.5h what does this means?
This code is not listed in any material I can find, it is a fairly common question on this site but no one seems to have an answer. Please call a service technician.
E1 message on my LG Inverter Direct Drive Dishwasher
An F1 usually means a communication error between the control board/touchpad and the motor/pump assy. Could you please supply the full model # for your unit?
Sandstrom dishwasher showing f9
please i have a dishwasher SDW60B12 , i live in spain and no body knows this brand here. So the error code is F9, please anybody knows what does it mean.?.. please i called an engineer buy he does`t know about it. Pleaseee.
Nov 06, 2013 • Dishwashers
I have fisher&paykel dishdrawer and f1 problem. what doew it means;
Hi
Please check this link to troubleshoot your problem in dishwasher if it shows F1 error:-
http://www.ehow.com/how_7307602_troubleshooting-error-fisher-paykel-dishwasher.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 • Dishwashers
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Hi my dishwasher element not heating up.wht might be the cause of it?
It probably is a bad fuse. Try changing the fuse. Look at the element for damage as well. Turn it on and test the current to the element and let me know how many volts you got. You need a voltage meter for that. It may not be getting enough power to it.
Hi my dishwasher does not wash. It takes water but no spraying. Any ideas wht it can be?
Your main wash motor has failed & needs to be replaced or unblocked.
Feb 21, 2011 • Dishwashers
3answers
Dishwasher not draining
Thanks for writing to Fixya.com.
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
1helpful
2answers
Where can i find free driver for MP3 Player and pen drive c / Radio Recoder 256MB and A225 Black tecnoshow
hi
sir
i have sony pendrive walkman nw e002f , i formatted that becoz of virus. After that i add lot fo mp3 song into that but now it showing FORMAT ERROR.. wht is this .. i cant play song ...why it's like this ..wht is the solution for this??
Top Dishwashers Experts
Mike Cairns
Mike Cairns
