Juki DDL-8700 Logo
j
johanna wakeling Posted on May 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cause of oil dripping from needle shaft - Juki DDL-8700
Debbie
Level 3:
  • Juki Master 1,860 Answers
  • Posted on May 03, 2016
Debbie
Juki Master
Level 3:
Answers
1860
Questions
0
Helped
385207
Points
9030
Possible over oiling, or if it has a reservoir to put oil in , then the reservoir may need to be checked for leaks
My Riccar 9700 has a squealing handwheel. I've taken off the cover from the arm. I've cleaned and oiled every moving part in the manual. What is causing this squealing?
Turn wheel until needle rises as far as it will go, Lubricate that bar inside that goes up and down above the bracket or housing that holds it, Also take note if there is a lower bracket that also needs to be oiled. Make sure you got the bushing around the turning shaft nearest the handwheel, and make sure there is not a thread wrapped around the shaft nearest the handwheel. (Behind the handwheel,)
How do I oil my Brother EX808 Sewing Machine?
Oiling the needle bars
  1. Too much oil may drip onto sewing project.
  2. Put a drop of oil onto the hook once a day before use.
  3. Apply one drop of oil on the lower needle bar above the felt washer every 40 - 50 hours of sewing time.
  4. Apply only sewing machine oil. ...
  5. Do not apply too much oil.
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
3answers
My foot pedal wont move the needle, and my handwheel wont budge. Nothing i can see is causing it to bind. What could be the problem?
it may be cotton threads around the bobbin shaft causing it to jam up
take it to a sewing machine service center and have it serviced
Needle shaft stuck. Machine won't work.
It's possible that you have threads wound somewhere inside the machine. Likely places are the tension unit and near the hand wheel.
2helpful
My sewing machine won't zig-zag stitch
There is usually one source for this problem, and it's easy to fix. Take the end cap of your machine as if you were changing a light bulb. Now you are off...When you switch from straightstich to zigzag, the levers operate across and inside the body so that the needle shaft, you watch it going up and down, can also move sidesways (but only a few mm's (about 3/16 inch)) The needle shaft should both go left and right, freely. It is hinged at the top but half way down ththe shaft it "floats" in a two sided guide. This sounds complicated but it truly is NOT. What happens to neglected machines is that "gunge" forms in the sliding parts and stop the left and right deflections. You my need to prise open the shaft from it's guide to start with (be gentle) but a few drops of oil normally soon allows the needle shaft to slide side to side.
When you can shake the needle shaft from side to side BY HAND (with the machine set in the zigzag mode) replace the end cap and start zigzaging.
And in future oil your flaming sewing machine.....
When it changes from straight stitch to sepintine and back to straight it skips lots of stitches. Just paid $300 for a new shaft.
try these suggestions & see if they help
Sewing machine skips stitches
1.needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
2.Correct needle insertion is mandatory for proper use.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
1helpful
I have a Singer Serenade 30 and have set everything according to the manual for zig zag but it still sews straight. Help!
Make sure that your needle shaft is not stuck, move it back and forth, oil if necessary. I had it happen to me once, but mine was caused by a bent needle shaft after loaning it to someone, and I had to do this each time I wanted to zig zag stitch. .
1helpful
Oiling XL-5700
You oil this machine anyplace that it moves and rubs. Needle bar, joints that drive the needle bar,end of each shaft, presser foot bar,hook race etc. Do not use 3 in 1 oil. Use a good quality sewing machine oil.
sewman7
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
