Just bought an EZgo Golf cart and not sure/year/make/modle but have a question an the brake lights? Tail light work fine but brake light do not come on when brake applied, is the a fuse?
https://shop.ezgo.com > Shop > Parts > Brake Parts > Brake ShoesOEM Golf Cart Brake Shoe 4084 ' Single Shoe. Fits 1996-current E-Z-GO Golf Car and Utility Gas & Electric Vehicles. Item #: 648037. $24.70/ea. Spring- Shoe Return- LH (Blue). Used on 1996-Current E-Z-GO Gas & Electric 4/6 Passenger Shuttle, ST Express, 875, 881, 950, and Cushman Titan Vehicles; in addition to ...
www.golfcarthotrod.com > Golf Cart Repair Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
Most people do not trust the old oil pump used on the 3PG models, me included. Mix 50:1 and you can be sure that the piston and crank will not seize up.
