Question about Rotel Rsp-1068
Standby button no longer clicks on and off.i turn it on and off by connecting and disconnecting the cord.is there anything I can do ?
    New Friend:
Does anyone have a useful answer? There is a power relay underneath the main power input board. It could be worn out. Does the unit make any clicking sound when you plug it it?
Posted on May 23, 2016
  • 731 Answers
Yes, take it to the approved repairer for this make of equipment.
Posted on May 03, 2016
SOURCE:
My Foxtel box will not turn on, I checked batteries not that.
Box won't come out of standby - Support - Foxtel
https://www.foxtel.com.au/support/tv/troubleshooting/.../foxtel-boxes/standby.html
Reset your Foxtel box by switching the power off at the socket, then pull the power cord out from the back of the box. Leave the power disconnected for at least 30 seconds. Plug the Foxtel power cord back in and switch the power on. Your Foxtel box should turn on and light up.
Foxtel box has no lights - Support - Foxtel
https://www.foxtel.com.au/support/tv/troubleshooting/.../foxtel-boxes/no-lights.html Step 1: Check the power cord is connected securely. Check the power cord is secured tightly at the back of your Foxtel box and at the power socket. If your remote isn't working, troubleshoot your remote click here.
Solved: Box will not turn on - Foxtel Community - 30431
https://community.foxtel.com.au/t5/Foxtel-TV/Box-will-not-turn-on/td-p/30431 My box is frozen with the green light on. Have tried unplugging and leaving for a couple of hours but it still will not turn on whether using the remote or the button ...
Solved: Foxtel wont turn on - Foxtel Community - 10049
https://community.foxtel.com.au/t5/Foxtel-TV/Foxtel-wont-turn-on/td-p/10049 Does the box stay in standby mode - the light staying red instead of turning green? If the orange light is flashing on the box when you use the remote then the ...
Foxtel Now box start up issues - Troubleshooting - Foxtel Now
https://www.foxtel.com.au/now/support/troubleshooting/box/startup-issues.html Troubleshooting and tech help for your Foxtel Now box if it does not boot up successfully or won't turn on.
May 11, 2018 | Televison & Video
Unit stays on standby
The only thing I can find in the manual (link below) is to remove the power cord for a few minutes & try powering on from the "Standby ON" button, also set the "source" to anything other than TV. http://www.p4c.philips.com/files/l/lx3600d_25/lx3600d_25_dfu_eng.pdf
Jul 07, 2007 | Philips LX3600D System
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
SONY BRAVIA KDL-46S2000 NOT TURNING ON
Look for loose contacts in power outlet. Try the TV on some other power outlet. There could also be a problem with the power cord.
Aug 05, 2012 | Televison & Video
32" vizio m370nv, not under warranty any longer,
Hi I was in a live session with you earlier but there was no response for about 15 minutes so I thought your were disconnected. Please click on the re-connect button or you can respond here. When you say it does not turn on, does the LED change color but there is no picture or is it just stuck in standby mode? Please provide this info so that we can continue with the diagnosis.
Apr 05, 2011 | Televison & Video
Seems to be some sort of power problem since the READY light is no longer on, and therefore the remote control cannot turn the receiver on, nor can pressing the power on button turn it on.
If there is no standby light. Open the top cover and check the fuse on the primary power side. MAKE SURE THE POWER CORD IS UNPLUGGED.There are two transformers in this model. A small one for standby and a large one for the main section.A relay clicks when you touch the power button and switches on the large transformer and the display comes on. If there is any problem in the output stage the the relay will click and the system will go into standby again.
Mar 10, 2011 | Denon AVR-75
It wont turn on but the box light is orange
The orange light on the brick indicates that the power supply is in standby mode. This can happen when the power supply cord is not fully inserted into the 360s socket. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord. If your using an extension cord of some kind, disconnect and instead plug it directly into the wall socket. Hope this helps!
Try using another Power outlet or try turning it on by pushing the eject button. Your power button may be defective. I'm sorry, but if that doesn't work I'm afraid your gonna have to call 1-800-4-MY-XBOX There may be something wrong with your console.
Jan 29, 2011 | Video Game Consoles & Games
When printer is turned on it reads 256MB and that is it. No menu buttons or anything else will work. Never get ready light.
First, try to unplug and wait 30 sec. then replug the printer into the wall to try to reset it. Then, read below to see if there is a solution if the '256mb' display problem persists. Control panel display is blank No display message Cause Solution The printer’s on/off button is in the standby position. Verify that the printer is on. Fans might run while the printer is in standby mode (off). The printer’s memory DIMMs are defective or installed incorrectly. Verify that the printer’s memory DIMMs are correctly installed and are not defective. The power cord is not firmly plugged into both the printer and the power receptacle. Turn off the printer and then disconnect and reconnect the power cord. Turn the printer back on. The line voltage is incorrect for the printer power configuration. Connect the printer to a proper voltage source, as specified on the Power Rating Label on the back of the printer. The power cord is damaged or excessively worn. Replace the power cord. The power source receptacle is not working correctly. Connect the printer to a different power receptacle. Printer is on, but nothing prints Cause Solution The printer’s Ready indicator light is not lit. Press STOP to return the printer to the Ready state.
Jul 14, 2010 | HP LaserJet 4700 Printer
When console is turned off the light is glows yellow instead of red.
Yellow just means that it's on standby. If there's a new message or there's an update, your Wii will start blinking blue.
If you want to turn it completely off, just go to the Wii menu, Click the Wii icon (Options), then click Wii settings, click the right arrow to get to Wii System Settings 2, then click on Wii Connect 24, then click on Standby Connection, then click off.
Don't worry about the heat. It's normal when you have it on standby.
Jan 15, 2010 | Nintendo Wii Console
I just replaced the lamp on my sony wega 42WE655 tv and the lamp replacement indicator light onthe front no longer indicates that it is bad, but the standby light keeps flashing red. when i try to turn it...
If you just replaced the lamp then there's something wrong in the power circuit or you have a bad lamp. If you can I would take the back cover off and look at the board where the power cord connects and lok around it for swollen capacitors. Let me know if you find anything.
Oct 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Rotel Rsp-1068 Logo
160 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
