I have tried everything from unplugging to changing batteries.I have had to purchase a universal remote cause the Panasonic remote not responding anymore
This is for a diff. model but give it a try, they may be diff. #'s showing up then what pops up on screen then is listed below.
SOURCE: Dvd player won't power up
Hi. In most cases the reason you get this problem on DVD players, Vcrs, Cable boxes is down to electrolytic capacitors in the power supply. Look for any caps that are bulging or may have wet stain on the circuit at the bottom of them. Any bulging or leaky caps will need replacing. Im not familiar with this machine so sorry I cant give you position numbers.
SOURCE: dvd recorder remote control
Anytime your unit displays RC1, 2, or 3 - the remote code needs to be reset. Other messages are "chk remote n" or "set n", n being the number 1, 2 or 3. These remote codes are set in case you have multiple products that interact w/ the remote - so when operating one device the other doesn't interfere. Unfortunately, every now and then for completely unknown reasons, they can slip out of the proper code. All you have to do (if your remote is, in fact, functional) is press and hold the number on the remote that corresponds with that which displays on the unit - in your case the number 3, and hold the Enter key at the same time for about 5 to 10 seconds. This should resume operation shortly thereafter. However, you will not see any confirmation on the display as you are performing this reset. It is trial and error.
SOURCE: remote not responding
Are you holding enter and channel number at the same time for about 2-5 seconds
SOURCE: Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
SOURCE: My 2 yr old nuked my remote for our Panasonic DVD
i think you better can order an original one,its always the problem that some functions wont work
Testimonial: "haas1703 was very honest! very much appreciated! My gut was telling me that an orig remote was prob. best way 2 go, without all the remote tryouts :)"
