2006 Dodge Grand Caravan Logo
Kelly Oetzel Posted on May 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Burning bitter smell coming from vents, heat works intermittently
I get cool air when I turn on the heat in my van. If I turn temp dial from warm to cool and then back I can get it to start putting out warm air. I have also started smelling a burning smell, not sweet but like a bitter smell from vents. Wondering what this could be and if it is an easy fix.
Tony Crow
Level 3:
Master:
  • Master 578 Answers
  • Posted on May 02, 2016
Tony Crow
Master
Level 3:
Master:
Answers
578
Questions
Helped
143268
Points
1638
Probable armature burning , check blower brushes
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
1helpful
Smell of burning oil out of heater vents
Have you checked under the hood,Mark? The heater commonly pulls outside air thru the vents and can get air coming up from the engine,so I'd look for a smell outside the car,under the hood.Let me know what you find.
You can alleviate it some by using the recycle air button on your heater,but you need to find the source quickly,so you don't have a fire. don-ohio (:^)
2005 uplander... temperature dial on cool, getting warm air
sounds like the air mix rod is out of adjustment or if vacuum controled, its leaking can you hear a noise in the vehicle or can you find a vacuum hose off in the engine bay hope it gives a little help
5helpful
2answers
Driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
2004 Odyssey, heat and A/C do not work unless van in motion
Since warm air eventually comes out when the vehicle is in motion, you may have an air mix door that is stuck in fresh or is somehow blocking warm air from the heater core.
To see if the air mix control motor is bad, you need to retrieve your Diagnostic trouble codes (DTC's) from the heater control panel. To run the diagnostic function, do the following:
1. Turn the ignition switch ON (II).
2. Turn the fan switch OFF.
3. Press the recirc control button to select Recirc (recirc light on.)
4. Press and hold the recirc button to select Fresh (recirc light off) and continue to hold the button down until the recirc light comes on for two seconds and then goes off.
5. If the system is okay, the recirc light stays off.
6. If there is a problem, the recirc light blinks the DTC to indicate the trouble. One blink=a problem in the air mix control motor circuit. Two blinks=problem in the mode control motor circuit
Three blinks=problem in evaporator temp sensor circuit.
7. Turn the ignition switch off to cancel the self diagnosis function. Run the diagnostic again after repairs are complete.
Note: the air mix control motor has a rod which connects to a plastic link. The link controls the mix doors and also connects to the heater control water valve via a cable. The air mix motor may check okay, but if the link is broken then you will still have problems. the motor is on the bottom of the heater unit in the front passenger's foot well.
Heating problem, temperature gauge
there should be a dial to control the center vents. i believe its in between the vents or just below it. it should have blue and red marks on it. move the dial towards the blue indicator and the air should now be cool. in cold weather, move this dial towards the red indicators for warm air. you can adjust temp at these vents by moving the dial between red & blue.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
