SOURCE: SD card won't stay in camera
Quick fix... Roll a little piece of paper up or fold into a small square the set it on top of the memory card and tape that down. so that it puts pressure on the card and keeps it seated in the slot. It sounds like the spring inside the camera is broken. which you will need to have sent out to be repaired unless you have a local camera repair person. And that is going to take about a month. Actually more... unless you find a local repair person. Because Sony bought out minolta a couple years ago and shut down all the minolta repair centers and got rid of almost all their parts. I once had a customer who sent in a minolta to get it fixed and it took about 8 months to get it back. Because of parts.
So You will probably want buy a new camera. but there are still a lot of those Minolta's around on clearance and you can get a great price.
Hope that helps,
Caleb
SOURCE: Can a SDHC card be used with a CF card adapter in Nikon D70s?
You would have to get an SDHC to CF adapter which could be pricey and they are hard to come by.
SOURCE: Memory card is locked w. Canon Powershot SD1000
Your Sd1100 is compatible with a 4gb card, so that's not the issue. If the lock-switch is in the correct position, the only logical conclusion (which you have already come to.....good troubleshooting on your part!) is that the camera is busted. Send your two "friends" the bill. What a drag.
SOURCE: memory card will not stay down in a nikon coolpix s210
Hi, I have exactly the same problem. However, instead of getting a new body with a broken screen and exchanging my screen (One of the only ways round it) I thought I'd try something.
I folded a piece of paper (Quite a small piece) and put in on top of the card when it is popped. I then just closed the battery/card cover and it stayed in place. This is a cheap way of fixing it, it's now been fine for a while, it's a bit of a shoddy fix but it's better than paying nikon £50 to get it fixed.
It takes a couple of trys, getting the paper the right size was a little bit of a pain but it now works fine.
Good luck,
J
SOURCE: pictures taken with camera and no memory card inside how to
There is a copy option on the playback menu.
This copies to and from the memory.
