I have a cable box, Blu-ray player and Roku 2 plugged up to my apex TV. I can not get audio from any device except the Roku. I have swapped inputs and cables but no luck. The other devices will play audio if it is plugged up via rca. I can't use rca audio and hdmi video because as soon as I plug up the hdmi I no longer get audio from the rca. It is set pcm. I do think K of what is different about Roku audio.
SOURCE: Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
SOURCE: APEX Digital VCR&DVD PLAYER ADV-3800 will not play DVD's.
What it so far done, it looks pretty fine. I'd break apart the problem if is posible to do it, i mean maybe you have some other sets around the house or some friend who have them.
i would start over again the installation after this test.
the reason is to know if you can trust in those sets and second maybe with some other try the installation works
SOURCE: I put a regular dvd into my blu ray player but it
Assuming it will play regular DVD's I'd suggest you connect it by scart also and set your TV input to scart.
I don't think DVD's carry High Def. data, that being the case, your player may auto route the data via scart.
SOURCE: Just purchased a new samsung blu ray player with
onkyo receivers have a problem, see
http://www.hdtvsupply.com/hdmi-cable-booster.html
