Question about Jabra BT650 Bluetooth Headset Halo
Followed all set up, no ringtone after 24 hours
Tried disconnecting for ten mins, no help. no incoming calls either. Help please!
How do I find ring tones on my Alcatel one touch pixi?
Ringtone for all calls
  1. From the Home screen, tap the Recent Apps key all+aps.png to bring up the Menu.
  2. Tap Settings.
  3. Scroll to 'DEVICE,' then tap Audio profiles.
  4. Under 'PREDEFINED PROFILES,' tap General.
  5. Tap the Settings icon.
  6. Scroll to '[INCOMING CALLS],' then tap Phone ringtone.
  7. Tap Phone ringtone again.
  8. Tap the desired ringtone from the scrolling list.
  9. Tap OK to confirm.
May 23, 2014 | Alcatel Cell Phones
Just got a loaner phone until August. I cannot find how to change the ringtone. I do not like the current ringing. Please help.
Hi just go to the setting menu of your phone.choose call setting and choose incoming call the change the ringtone and activate it..
Jun 22, 2011 | Sony Ericsson Cell Phones
How do i mute incoming call on samsung s7220
Hello Sir In Idle mode, press and hold # to silence or unsilence your phone.
And To change Your Ringtone follow these steps ! Change your ringtone Phone ? Settings 1. In Menu mode, select profiles . 2. Scroll to the profile you are using. > Voice call ringtone ? Edit
May 05, 2011 | Samsung Cell Phones
On the SAMSUNG SGH-ZV40 how can i change the ring tones. can i get a step by step guide as my screen has broken
Hi Lilfranza,
Menu structure is: Menu/Settings/Profiles/Normal Profile/Options/Incoming Call/Voice Call Ringtone see details below
Sound Settings
You can customize various sound settings.
1. When the Idle screen displays, press the Menu soft key.
2. Select Settings and press the Select soft key or the Cingular icon key.
3. Select Profiles and press the Select soft key or the Cingular icon key. Use the Down
Navigation key to scroll through the following list of available options:
Normal Profile
To access the available options for this calling profile, press the Options soft key.
Highlight Edit and press the Select soft key or the Cingular icon key. Use the Left and Right
Navigation keys to move between the various tabs. This menu allows you to alter the
audio settings for the following categories:
• Incoming Call: allows you to edit the properties for audio alert used for incoming
phone calls.
-_ Voice Call Ringtone: allows you to select a ringtone from your My Stuff (Phone)
folder which contains not only the default phone ringtones, but also any new
ringtones which have been downloaded from the Internet.
Mar 15, 2011 | Samsung SGH-ZV40 Cellular Phone
Purchased B5722 samsung cell phone yesterday. Kindly assist me in solving the following problems: (a) Cell Phone Sim1 and Sim2 both reject calls made from residence Landline, but when calling from Sim1...
Dear Please find the answers below:
(a) Cell Phone Sim1 and Sim2 both reject calls made from residence Landline, but when calling from Sim1 and Sim2 to residence Landline, both calls go through.
This is actually the problem of service provide I think as this some times happens with me as well, try other landline nos, if it works it is not the handset problem.
(b) To set Ringtones to Call Alert Sim1, tried: Menu - Settings - Phone Profiles - Normal - Voice Edit . The screen does not change on pressing Voice Call Ringtones. Spent countless hours trying to set Ringtones for incoming calls of Sim1 & Sim2, Messages alert for Sim1 & Sim2, but did not succeed
You have to do as follows: Menu - Settings - Phone Profiles - Normal - Edit - Voice Call Ringtone - Music - Card / Phone and chose your required Ring tone.
(c) Could not clear multiple Icons overlapping each other on main screen.
You have to tap on the Screen the Widgets will come on left side. Put your finger on the Icon - Icon will increase in Size - now without picking the finger from Screen just drag the icons on the Left Widget Slider bar, it will go on it.
Prompt reply shall be sincerely appreciated
Hope this will help.
Nov 29, 2010 | Samsung B5722 Cell Phone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Just noticed that all incoming calls vibrate
You may have accidentally set to airplane mode. Check to make sure this setting is NOT enabled.
Sep 29, 2009 | Motorola Mobility W385 Cellular Phone
Downloaded a ring tone with the memory card but when i load it on the phone it will only play as music, can't set it as a ringtone.
Hi friend,
Could you tell me if your cell phone can support the function?
You can check like the following:user profile-General-Customize-Tone setup-Incoming call,then you can see many ringtones in it,Could you see the icon"empty"?If so,you can set the ringtone you downloaded as the ring tone of incoming call.You just need to find the ring tone you downloaded,and transmit it to the "user profile".
But if there doesn't have any "empty" icon,I am afraid that you cannot set it.But you can try to cancel some ringtones ,and replace them by the ringtones you downloaded.
You can get much detailed information in the website:www.1010store.com
Sep 15, 2009 | LG Xenon GR500 Cell Phone
Ring tones
To change ringtones, go to Settings, phone profiles, highlight the profile you are using, choose options, then edit, the screen will show the settings for incoming calls, here you can scroll down and change the call ringtones, highlight voice call ringtones, press options,choose change, this takaes you to My files folders, go to the folder you keep your tunes in and highlight the song you wish to use. press options, then select. Press options again and then save.To change text tones, you do the same, but once in the screen to show settings for incoming calls, you must scroll right to show the new message screen, then you can choose the song you wanat in the same way as for calls. remember to save tho.
Jan 09, 2009 | Samsung SGH-F400 Cellular Phone
E815 Ringtone Problems
The formatt of the ringtone you have recieved might not compatible, if it is polyphonic try to download midi format.
May 05, 2007 | Motorola Mobility E815
Jabra BT650 Bluetooth Headset  Halo Logo
63 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
