Model es400
Hey Scott, thank you for your inquiry!
Based off the information you have provided your Frigidaire range is displaying an error code of "F7" and it is beeping. Typically, "F7" stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F7" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Testimonial: "Thank you I will try it"
SOURCE: frigidaire cooktop beeping f7
Hi Bobbiflower,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Hi Bobbiflower,
Happy to help you!
1-800-905-9505
They answer 24/7
Thank you Neil
SOURCE: oven and control panel not
Sounds like a stuck keypad. Push all pads at random several times each then try it again. If that does not work the clock will have to be replaced.
