lin fern Posted on Apr 29, 2016
I couldn'install new vers. what should i do? - Walkman Sony Audio Players & Recorders
1helpful
Serial number for epsxe3 emulator intallation
The ver # (not serial #) will be on the label either on the bottom or back of the unit. expressed as either v. or ver .
Here's a link to the manual.
Do a factory reset, then install like a new unit. http://downloads.linksys.com/downloads/userguide/1224638357428/epsx3_ppsx1_ug_0.pdf
tip
Trouble Shoot and Bullitens
SC120 Displayed instead of SC122 when the scanner home position was initialized 001b BICU engine firmware Install new BICU engine firmware
SC142 Intermittent or continuous 025 Defective CCD (vapour from adhesive) Replace the lens block assembly with one that is not defective.
SC280 In color mode (2C or more) with LT LEF and duplex, SC280 occurs falsely if 5 or more originals are scanned during machine warm-up. 001b BICU engine firmware Install new BICU engine firmware (ver. 1.242.01 or later)
SC280 False detection when the main motor direction changes from backwards to forwards 001i BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.31:01 or later)
SC305 008e Toner drops from the dev. unit, between the charge corona cleaner slider and cleaner driving screw
Clean the screw and slider with a damp cloth.
SC410 Unnecessary SC410 generation 001d BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.262:01 or later)
SC420 Unnecessary SC420 generation 001e BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.275:01 or later)
SC481 022 Torn image transfer belt Install a new PCU.
Asus p4b266 vers 2.01
Is your power supply works ? (check the fan)Check if power supply connected correclty with the motherboard (see manual)if yes then change power supply with same type of bigger in Watts and retry.
I tried to install windows xp on sata hard disk but it couldn't find any hard disk in installation.in bios i can see the hard drisk that it shows RAID hard disk 60gb.my msi model is ms-7113 ver 1.what...
get to BIOs ..locate the hard disk ..and change the setting from the ACHI ..to sata like ide..or compatible ..Or ..use use a usb ..or a floppy ..to enter a raid driver for it ..when you install it ..If you pay attention ..when you run the installation of the xp ..Just after starting to load files ..(soon after press any key to boot from cd ) ..it says to press f 6 for to load 3rd party driver ..press it ..and use some kinda memory device ..that will be see..and load teh driver ..and will work )
Or ..just disable the sata raid ..for the hard disk ..and it will be seen after that when you load the operation system ..If it is a newish model ..it will not be affected ..only old models feel the difference in speed between the modes..
Do I have to uninstall "MP Navigator Ex 1.0"
Unless specified, the installer will automatically remove the older version and replace it with the new.
1helpful
Installing new version of Flash Player on Firefox ver 2 - Win98se
You have to make sure your Firefox is closed first, otherwise it won't work or installed. Install the Flash Player. And then only start your Firefox.
Chat function in ATT Yahoo mail says it needs Ver 9.0.115
Good day!
How about try this link
http://ph.messenger.yahoo.com/
Hope that will help your problem.
Thanks
Can't upgrade adobe reader from 7.0.5 to 8.0.2. says that i need to verify the patch package
You may have to do a clean install instead of upgrade. Download a copy of ver 8 from adobe.com, uninstall ver 7, and install ver 8.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
