Motorcycles Logo
Lisa Hopkins Posted on Apr 29, 2016
I have a 97 Honda shadow spirit. I have change the thermostat and the fan switch. And the temperature light still is coming on? Water pump is working! Help please
1999 Honda Shadow Aero, temp light on fan not coming on
yap it has a termo sensor, if it fails, your fan wont turn on, and also check the auxilliary fan relay.
Motorcycle...1988 honda shadow 800.overheating,,tested fan works ..figured it was the thermo switch,put new one in filled up antifreeze,,still overheating,,does this bike have a thermostat in the...
the coolant sensor is in hot water and doesn't have to have circulation work
Check with a service center but as water circulation is controlled to maintain correct engine operating temperature
it should have a thermostat in the system
3helpful
2answers
When I run my bike for an entended amount of time, my temp light comes on and my fan never starts to run. What could be the problem?
If your bike is actually overheating and the fan is not turning on. You either have a bad fan switch ( screws into radiator and has two wires ) or a bad fan motor . A bad fan switch is fairly common on Honda's. The bad news is the switch is about $100 . Try jumping the wires to the switch to see if the motor is bad or not. If the bike is not actually overheating, you could have a temp sender giving the light a false reading. The temp sender is located on the thermostat housing and runs about $50. Remember, Shadows have small radiators and tend to run high on the temp gauge, and , Honda gauges tend to not be that accurate as they age.
1helpful
2002 Honda Shadow DC750 Spirit - Ingition switch won't engage
Check the wiring connections inside the headlamp shell. They tend to pull apart from vibration and corrode from water entry into the shell. If the start button is indeed frozen (will not move at all)--replace it. Hope this helps!
2answers
1998 HONDA SHADOW 1100 ACE TOURER AS I WAS
you might want to have your water pump looked at.
1helpful
I have a 2004 Honda Shadow Sabre not charging&fan not working...
I have a 2002 Shadow VT1100C. I recently had to replace the radiator mounted thermostat switch because it did not come on.
Unfortunately I ran the bike until it overheated before I discovered this. The overheating caused my stator to short out to ground (frame). No stator=no charge voltage=dead batttery quick. So I had to take apart the crankshaft, and replace the stator along with the radiator mounted thermostat switch. You will need a shop manual. You need to know how to measure voltage and resistance with a meter. If you need a stator, buy an aftermarket stator because the OEM versions cost 3 times as much.
Adrien
2helpful
Overheating 97 V6 pontiac grand am
1 Inspect Cooling System Mix Coolant level low or flow is restricted. grey_line.gif 2 Inspect Belt Incorrectly routed, adjusted, tensioned, missing, or worn water pump belt(s). grey_line.gif 3 Inspect Oil Pan Gasket - Performance Ruptured, cracked or leaking radiator hose. grey_line.gif 4 Inspect Radiator Cap Worn or damaged radiator cap grey_line.gif 5 Inspect Thermostat Thermostat stuck closed grey_line.gif 6 Inspect Fan Blade Broken, missing, or defective fan blade(s). grey_line.gif 8 Inspect Water Pump Damaged, worn or leaking water pump. grey_line.gif 9 Inspect Intake Manifold Plenum - Perform Leaking water pump gasket. grey_line.gif 10 Inspect Cooling Fan Control Faulty cooling fan control or circuit. grey_line.gif 11 Inspect Cooling Fan Switch - Radiator Faulty radiator cooling fan switch or circuit. grey_line.gif 12 Inspect Engine Temperature Sensor Faulty engine temperature sensor or circuit. grey_line.gif 13 Inspect Temperature Switch Damaged or faulty temperature switch or temperature switch circuit. grey_line.gif 14 Inspect Fan Clutch Worn, loose or faulty fan clutch. grey_line.gif 15 Inspect Ported Vacuum Switch Damaged, leaking, or faulty ported vacuum switch. grey_line.gif 16 Inspect Radiator Obstructed radiator core or radiator cooling fins. grey_line.gif 17 Inspect Head Gasket - Performance Head gasket leaking coolant into cylinders
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
