How old is the system that you are hooking it up to? Original ipod docks charged through a different pin configuration that current ones. If the dock is older, it will not charge newer ipod devices.
If it is a different model iPod then it is likely the Bose dock does not support the newer model. Quite often changes such as from iPhone 3 to iPhone 4, Bose had to release a new dock. The speakers and music will still always work, but the support will be limited for charging. Unfortunately you will not be able to fix this, other than upgrade the dock, or go back to your old ipod.
Maybe this could be the solution... Source: http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html "... Important Note: iPods released since Sept 2008 (e.g.
Touch 2nd Gen, 4th Gen iPod Nano and iPod Classic 120 Gigabyte, iPhone
3g and onwards) have an updated dock connector that means older
revisions of speaker dock may not be able to charge these newer models
of iPod/iPhone. Older docks should play music from these newer models
with no problem. The problem with charging is due to Apple
removing support for 12v (firewire) charging on these new models of
iPod/iPhone. Only 5v (USB) charging is supported on these new models. ..."
Easy, I had this problem too. The reason it isn't playing is because its not in all the way. I was getting very frustrated with this, so I kept trying to push it onto the dock to get it all the way down.
Solution:
1. Play a song on your ipod/iphone so you can hear it through the device.
2. Connect your ipod/iphone to the docking station(Bose) so that you hear the chime(This lets you know its charging).
3. Pick up the docking station and firmly press the ipod/iphone down on the connector.
4. Keep pressing it and wiggling around until you hear the music begin to play through the docking station.
It may take a few tries, but you will get it.
Hope this helped!
~ Jake
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen). If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
