Ovens Logo
G
George Boudouris Posted on Apr 28, 2016
My Dacor gas oven PGR305 does not ignite the lower oven burner. The cooktop burners and broiler do work.
The convection fan turns on and the ignitor glows red hot but the gas doesn't seem to be coming out. I've replaced the relay board but the problem persists. Please help. Thanks.
5 Related Answers
Anonymous
  • 833 Answers
  • Posted on Dec 21, 2007
SOURCE: Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
vitg55
Vitaliy Gins
  • 78 Answers
  • Posted on Dec 10, 2008
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Anonymous
  • Posted on Dec 27, 2008
SOURCE: hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Anonymous
  • 21 Answers
  • Posted on Jan 13, 2009
SOURCE: Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
chasd60
  • 17 Answers
  • Posted on Jul 21, 2009
SOURCE: The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Frigidaire gas oven not heating. The broiler and burners work but the lower burner will not ignite. I replaced the igniter however that did not fix the problem. In fact, the new igniter does not glow. I...
Check for volts to the new ignitor. The ignitor draws current which opens the gas valve. If it is not glowing it is not drawing power. Test the ignitor,disconnected, with an ohm meter, it should be under 200 ohms.
Dec 28, 2013 • Ovens
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
2helpful
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jennair gas oven. lower burner won't light, i.e.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
1helpful
Broiler on top works but oven wont ignite
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
It might be possible that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
If you want to see a line drawing and a parts list showing the ignitor(s), go to searspartsdirect.com and enter in the model number of your oven and click on the links shown.
Hope this helps and best regards!
Jul 31, 2009 • Ovens
8helpful
2answers
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 • Ovens
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Dec 09, 2008 • Ovens
1helpful
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
