SOURCE: Xbox 360 Keeps Crashing
buy a fan for your xbox 360, if it continues contact microsoft and see if they have a solution, it could be an internal problem that needs repairing, i have the same problem but i am going to get a fan which will cool the 360, and reduce the chance of my 360 breaking
SOURCE: i need help xbox 360 black screen
OK, I think I can slove your problem.
There is a slide setting thing on your av cord that gives you the option of using TV or HDTV (look near the end of the cord that slides into the XBOX 360), You will see two choices for settings on the cord "TV" or "HDTV".
Just make sure that you have it on the correct setting. I had the smae problem. My XBOX 360 is not hooked up to HDTV, so for me it should stay on TV. But somehow when I took out the cord I accidently slide it to HDTV.
I simply slide it back to the "TV" Setting and in about 30 seconds it worked perfectly.
I hope this helps you.
SOURCE: gta IV won't work on my xbox 360
it has to do with your tv if you have a 50 pal tv u will need a 60 pal because the grafics are good
YOU TOO
i like aaliyah
you be like,,,when we gonna fu** aaliyah
ask her if she likes you
