SOURCE: LG WM-2277HW Water overflowing from soap drawer (compartment)
The water dispenser compartment is connected to a hose. Disconnect the hose where it attaches to the tub. You will find a gray mushroom valve, remove this completely or you can just cut back the rubber that covers the stem halve way. What is happening is the valve is getting stuck in the up postion, and causing the water to poor out the front. You should also be running a hot wash every so often to clean out the unit.
SOURCE: Water left in bleach and fabric softner after running load
You must take out the compartment and empty it out before adding any bleach the next time, there is a type of button way in the back that you press down on pull out the entire door and empty the water for the next washing. You must press down very hard the entire door does come out check out your book for instructions it is way in the back on the left hand side. This happens to mine once in a while not all the time.
SOURCE: Bleach Dispenser not relaesing bleach during cycle
I have the same model # and same problem!!!
Worked fine for few months and then it started.
Sears technicians came twice but couldn't fix the problem. Now they have ordered a new dispenser door. Sears said they changed the design. Will see if the new door will work. Hope that helps.
SOURCE: I have an LG WM2487 washer and I'm having several
Addressing your error code: We had the same problem with our washer and couldn't find anyone locally that wanted to even look at it. Hence, I had to find a solution myself. I stumbled onto a sight that had service manuals (not just owner manuals), and found that error code there. What looks like an upsidedown F is actually a lower case T, so the error code is really "tE". This indicates a Thermistor fault.
The Thermistor is located next to the heating element at the botom-front of the drum housing (you will probably have to lay the washer on its back to access it). It is in a soft rubber grommet that protrudes about a half inch out of the housing, just to the right of the heater.
In the case of our washer, when I pulled the Thermistor out of the grommet I noticed some rust on the metal part. I simply rubbed the rust off with my thumb, inspected it again, unplugged and re-connected the connector a couple of times, and tested the washer again.
Results: We have now been using the washer for a couple of days with zero errors, and this was a tenacious fault that interrupted every load before. We are finally happy again with our very expensive appliance. I sincerely hope that this helps you and anyone else with this problem.
SOURCE: water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
