Uniden DECT 6.0 Cordless Phone ID Logo
S
Steven Jordan Posted on Apr 27, 2016
My handset says "searching" and doesn't have a dialtone. I tried a Basic Reset and it didn't help.
  • Brett Duxbury
    Brett Duxbury Apr 28, 2016
    Hi Steven Jordan, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Base unit is it powered on ? The box that plugs into the land line
  • Steven Jordan
    Steven Jordan Apr 28, 2016
    The base is ok. There is no dial tone on the handset, but there is on another cordless phone in the house. I inserted and charged a new battery and it didn't help.
Steven Leary
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Apr 28, 2016
Steven Leary
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
11
Questions
0
Helped
1183
Points
45
If it is flashing "searching" This usually means that the handset is not able to connect to the main Base unit connected to your phone line.
Testimonial: "I know. Is there a fix or do I have to get a new one?"
  • Steven Leary Apr 28, 2016
    Without an additional handset to test the Base with there is no way to really tell but would imagine it would be cheaper for a new system then to repair it
GE 27998GE6-C cordless phone with answering machine handset doesn't work
I can be of help please email me [email protected]
An upgrade can be offered, with lower call rates.
2helpful
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
I have a dual handset and on both it says searching...when i try to dial out i get no dialtone
try to take out the battery and then insert it again hope it will help you worked for some similar devices of mine
How do i program your 20200-1 hand set telephone. it has 13 number memory. that i wold like to program?
To program one of the three emergency buttons:
1) lift the handset and wait for dialtone
2) press the STORE button
3) dial the phone number
4) press the STORE button
5) press one of the three emergency buttons
6) replace the handset in the cradle
To use; lift handset and press an emergency button, the phone dials the number stored for that button
To program one of the ten memory locations:
5) dial a one digit number(0-9) to store the number in that location
To use: lift the handset, press the MEMORY button, dial the memory location digit(0-9), the phone dials the number stored in that memory location
Here is a link to download the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
No dial tone but the word "talk" appears and it lights up so I don't think the battery is dead.
I agree that the battery sounds good.
So, do you have another phone to confirm that you have dialtone coming into your home?
If so, then the two ends of your wireless phone are not communicating...
They will try to resync if you power both ends off for a few minutes (unplug the base and remove the battery from the handset).
After a few minutes off, reconnect everything and place the handset in the base.....
After 5 or so minutes, test again. If it is NOT broken inside, it should provide dialtone (if it is coming into your home).
My tru9480 handset is saying connecting but won't connect and won't get a dialtone
Reset Procedure for Cordless Phones
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
1helpful
No dialtone on handsets, 3 beeps sound
Deregistered 4 handsets, on suggestion from FixYa, by pressing hangup & # sign.
Then reregistered to base.
6helpful
2answers
No Dial Tone 1 Handset
I think I have the same phone. You have to put the handset with no dialtone in the main charger for about 30 seconds to reset it to the base.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
