Step 1
Locate the "Clock" button on the display. The display is located above the oven door. It clearly shows the time and has settings for temperature, time and cooking.
Step 2
Press and hold the "Clock" button until the time starts to blink.
Step 3
Set the time with the number pad. Ignore the colons and enter the number straight through. For example, if the current time is 10:08, just type 1-0-0-8.
Step 4
Set AM and PM by pressing the "#" button. Press "Start" to finish.
To access the clock controls, press the "Stop clear" button, press "User pref," and then press "5." Use the number keys to enter the time as a four-digit number. For example, press the "1," "2," "3," and "0" buttons to set the clock to display 12:30. Press "Start enter +30 sec" to complete the process.
On GE ovens there should be a CLOCK button to press first. Then if the control has number pads 1 to 0 you enter the correct time and press clock or start again to finish. If it has no 1 to 0 pads there should be 2 arrow type buttons with + on one and - on the other. Press clock and then use + to go up or - to go down. Holding either button in will make it change fast. When you get close to correct time hit button slowly to finish. Hit clock button when time is correct.
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Hi
You need to set your clock
If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time
once the time is set you may need to push the manual button sometimes this button is identified by a hand
regards
Geoff Stove Recyclers WA
Push and hold clock botton, until display changes, then use the scroll controls to change numbers, then when the time it's correct, press clock again to enter settings
For the NW09DO, press the outer two buttons ("-" and "+") together and hold for three or four seconds. Then press "+" to advance the clock/time and "-" to go back.
When the correct time is showing, leave the buttons alone for four or five seconds.
