Question about Hyundai 2007 Sonata GLS
Driver side wet when rains
I have check everywhere,,, Car covered rug dry. slight rain and rug on driverside wet. I see water coming in from sunroof. (drips)... . The floor mat is not wet but the car rug is,, sigh. Could it b the roof,, I checked the drain holes and they seem to be cleared,,
    Top Expert:
  • Hyundai Master
  • 51,893 Answers
The air intakes at the base of the windshield are supposed to direct rain water to drainage ducts in the front door pillars. The ducts can become clogged with leaves and debris. This may be the source of water on the carpet.
Posted on Apr 26, 2016
SOURCE:
Hello. I have a Pontiac G5 2007. Rain water flooded the floor mat of my car. All the windows and sun roof were closed. The sun roof was dry, what might have caused this. Thanks in advance.
I had this problem once with mini-van that I owned and it turned out that the grill on the outside, at the base of the windshield had plugged with tree debris and the water could not find the drain hole so it backed up and came in under the dash and filled the cavity where the blower motor for the heater sits.
I cleaned that out, pulled the blower motor and dried the tub it sat in which by then had mildewed, then put it all back together and things were fine. The blower motor had shorted out by the way so I had the fun of buying and installing a new one.
Apr 01, 2017 | 2007 Pontiac G5
How do I unclog the windshield drain?
well, you could inspect it.
older post.
person 1 sprays car with water.
person 2 looks under dash and windows for leaks.
there is no other way. in fact this is stated in the FSM book on every car made, just this test.
if you cant see obvious damage , or cracked seals. then....test it.
Feb 20, 2015 | 2000 Isuzu Rodeo
Water on the drivers floor.
Does your car have a sun (or moon) roof? A leak in a sunroof will sometimes follow the roof over to the door post and down to the floor were the water will accumulate. This can be hard to find sometimes but having one person spraying water on the roof while a second one checks the inside of the vehicle you may be able to pinpoint the leak.
Hope this helps.
Bob
Jan 05, 2015 | 2002 Chrysler Concorde LXi
My 1999 jeep grand cherokee 4x4 when rains leaks water under dash on passengger side it get wet onlt when it rains?
Do you have a sunroof?you might need to clean drain tubes.have you had a windshield replaced?or it could be a body seem.you will need to remove panels and lift up corner of the carpet and run the garden hose over the area and check for water in vehicle.
Aug 24, 2012 | 2000 Jeep Grand Cherokee
Has anyone had water soaked passenger side floor mats and rug for 2011 Bz?
This is of concern.....especially if no recent rain.
Your vehicle is covered by warranty and should be checked by your local BMW dealership.
If there has not been any rain, but your floor is wet....it's possible your heater radiator core (radiator) under the dash, is leaking.
Seek immediate attention.
Cheers,
Jun 13, 2011 | 2011 BMW Z4
(2004 chevy impal ls)Both rear floor panels completly soaked everytime it rains!I laid 2 paper towels on top of my rear floor mats,both sides are getting wet from underneath the mats.Leak is not...
shop vac the carpet dry then spray garden hose around both rear doors or around doors and see if you get wet or see a leak. Also spray under vehicle on both sides of car and check for leak.
Mar 09, 2011 | Chevrolet Impala Cars & Trucks
2002 Honda Accord Wet Floor
most common problem is the a/c condensor tube is clogged and is under the car and needs to be cleared with compressed air. also the sunroof track has 4 drain tubes and the right front may be clogged or leaking. you can check that by pouring a cup of water down the right front drain tube in the sunroof track and see if water comes out by the right front wheel
Oct 31, 2009 | 2002 Honda Accord
Wet passenger side
I believe the problem is a leak in your heater core. The water would run down the inside of the firewall or near it thus running under the mat.
Nov 20, 2008 | 1998 Volkswagen Golf
Hyundai 2007 Sonata GLS Logo
148 people viewed this question
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
moony
Level 1 Expert
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
