Televison & Video Logo
T
Theresa Taylor Posted on Apr 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the codes for a vizio tv - Vizio Televison & Video
Alan Timperley
Level 2:
Sniper:
  • Expert 91 Answers
  • Posted on Apr 26, 2016
Alan Timperley
Expert
Level 2:
Sniper:
Answers
91
Questions
Helped
71843
Points
405
The attached link takes you to Vizio's website and has codes for a Vizio Universal Remote. It gives you universal remote codes for practically every brand of tv, including Vizio. Hopefully that is what you are looking for. Have a great day!
Need help programing my vizio tv to a blackweb universal remote
You don't program the TV to the remote, you program the remote to the TV
Find the Vizio codes on the paperwork that comes with the remote. There will probably be several codes. You need to try each one. Before programming turn the TV on manually. After put in each code try turning the TV off with the remote. Then try to turn back on and try volume up If OK everything else should work. Occasionally 2 different codes will turn off the TV in the test above. Use the one that allows the most functions to work
FINALLY not every "Blackweb" remote will control every TV You may need to get another one that specifically says it can control Vizio.
Urc-3021 manual
Jacqueline, Check the attached links codes for a vizio television, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remote Control Codes For Vizio TVs Codes For Universal Remotes
http://www.avsforum.com/forum/93-remote-control-area/710090-programming-remote-vizio-tv.html
Vizio TV Remote Codes
Can I use your remote universal Llz414
Wholesale VIZIO DPS-200PP-190 2950318703 POWER SUPPLY UNIT ,cheap price ,and orginal board ,good quality
https://www.abctay.com/vizio-dps200pp190-2950318703-power-supply-unit-p-1644.html
I have a vizio L13e tv trying to connect to a universal remote need to set ip address please help
I think you may be looking for the remote IR device codes for Vizio TV for your universal remote. I have the following codes listed for Vizio on one of my universal remotes: 1009, 1030, 1346, 1413, 1414, 1415, 1459, or 1461. Set your remote's TV mode to each code to find the one that works on your TV.
4helpful
2answers
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
23helpful
4answers
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
2answers
Code for Vizio tv
It looks like your remote takes a 4 digit code. Try the following codes:
Vizio 0891, 0912,1783
4helpful
2answers
146helpful
13answers
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
57helpful
13answers
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
