SOURCE: Carpet
have a look at the brushes are they turning and if they are can you stop them turning if you tuch them with your hand??? if you can stop them turning the brush drive belt is slipping get a new belt and fit it,,
problem sorted!!!!
SOURCE: Hi, Dyson DC25 brush bar very
Sorry to hear you're having difficulties with your DC25. If the cleaner feels heavy to push, it may simply be due to the machine's powerful suction - the soleplate is engineered to form a close seal with the floor surface for high pick-up. The tracklines on the carpet are nothing to worry about - they're a normal feature of operation of the revolving brushbar.
It's also normal for the exhaust air from the motor to become warm after a period of use. I note you've stated that the filters are clean, but you might want to take a look at the video embedded below to check you've washed them correctly. Under normal use, they should be rinsed under cold water at least once every 3 months, and allowed to air-dry. No detergents should be used.
If you have any further concerns about your DC25, please get in touch with us directly so one of our experts can provide the assistance you need. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Dyson Customer Service
SOURCE: Dyson DC41 brush won't spin
You need to check the belt hooked to the side of the brush (sometimes hidden by plastic)
SOURCE: Dyson DC41 animal complete stuck in upright
The wheels are probably jammed and won't recline. Mine was stuck pretty bad, and after a half hour of trying to figure it out I just picked up the vacuum and slammed the wheels pretty hard, and it came loose. No problem since. Pushing on it hard did nothing, and gave me the impression I could break the vacuum, but all it needed was a good jolt.
