Question about Janome Even Feed Foot w/Quilting Guide
I have a Janome Even Feed Foot and the actual foot has come off and I don't seem to be able to reattach it.
Can you assist me to reattach the foot?
2 Suggested Answers
SOURCE:
RichSew
  • 220 Answers
SOURCE: how does one attatch the fanome even feed foot to
It sounds like you may have the wrong even feed food. It should be a simple task to put on. the packaging on the foot should say its for Janome horizontal bobbin machines.
Posted on May 27, 2010
How can I release the pressure of the pressure foot so that I can do darning? My machine is a Janome Model 360. Thank you
If you are using the appropriate presser foot, you normally shouldn't need to adjust the presser foot pressure. The shaft on a darning foot or free motion quilting foot is shorter so when it is lowered to stitching position, the foot will not rest on the feed dogs or stitch plate. The extra space between the presser foot and the plate allows you to maneuver the fabric. (Be sure to drop the feed dogs so they do not interfere with the fabric's movement. Or, if the feed dogs do not drop on your machine, you should have a special plate in your accessory kit that covers the feed dogs.)
Jun 08, 2018 | Janome Sewing Machines
WHERE CAN I BUY A WALKING FOOT FOR MY RX-1804.
The Janome even feed foot will work with your machine
http://janome.com/en/accessories/sewing-machine-feet/even-feed-foot/
Jan 08, 2015 | Rex RX-1804
Feed dog problems
What is your stitch length? I have always followed the rule... Bulky/Long stitches, Fine/Small stitches. If you have a "walking foot attachment otherwise known as an even feed foot..you might give that a try as well.
Jul 22, 2012 | Janome Sewing Machines
How does one attatch the fanome even feed foot to
May 22, 2010 | Janome 8080 Computerized Sewing Machine
I want to find the right walking foot for the Janome 344
Janome has an even feed foot for their machines. Any janome dealer should carry them.
Feb 23, 2010 | Janome L-344 Mechanical Sewing Machine
Sewing machine maintenance, walking foot & free-motion foot
Is this a Janome MemoryCraft 9000? (I ask because the models seem to get mixed up in the threads)
If so, you can more than likely find accessories for the MC9000 either on eBay, your local Janome dealer (you can find the closest one to you @ Janome's website using the "Dealer Locator" feature) or even ... SEARS!
Sears contracted Janome to make several of their sewing machines (I think Janome might still be the actual manufacturer, but aren't 100% sure) and so the parts are compatible. You can even use a Kenmore Memory Card with a Janome MC9000.
As for oiling, if it's the MC9000 (much like practically all newer models) they don't need oiling. Though sometimes, you can dab a teeny-tiny amount of oil on the bobbin case if it needs it.
Apr 14, 2009 | Janome Memory Craft 9000 Computerized...
Janome 5124 keeps running after I depress foot
Greetings, I experienced the same problem. Mine only ran a few stitches. Foot pressure on the foot feed was always "tension" problem in my foot.
I turned the foot feed around and upside down.
I press on the foot feed at the open end not the pivot (cord) end. This has given me much better control. Janome had no options for foot feed adjustment or replacement, but this has helped greatly. You may have to practice to get used to it
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
How do you fit and use a quilters foot
The 1600-DB requires a special Walking or Even Feed Foot due to the high sewing speed, so ensure that you have the correct foot, as the "normal" top loading machine foot will not fit.
I hope these images will assist in showing how the fitting should look.
This is the Normal - WRONG - foot to compare:
This is the CORRECT Foot:
From the Janome Accessories Guide:
"The even feed foot walks over fabric to assist with smooth feeding. Fabric can be sewn without puckering as the fabric is gripped and fed by both the upper and lower feed dogs. This foot has been specially designed for durability and to work at the high speeds of the 1600 series.
Part Number - 767-403-016"
If you need a larger image or you want any more help with this, just drop a line through the "Contact Us" page at
www.bargainbox.com.au
Apr 29, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Janome Even Feed Foot w/Quilting Guide Logo
398 people viewed this question
Top Janome Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Carolyn Rogers
thinksewfast
Are you a Janome Craft and Hobby Expert? Answer questions, earn points and help others
