Measuring Tools & Sensors Logo
m
mladen kutlesa Posted on Apr 25, 2016
On startup,remote sensor (TX29U) shows 302 than 00 than dashes -- and ---
La Crosse Technology WS-9160U-IT Digital Thermometer. The outside temperature stop working. I tried new batteries.
Question edited for clarity. Full 'make model (what it is)'.
Did you put batteries in both units and in the right order, sensor first?
Step 1: Insert 2 fresh AA, batteries into the TX29U-IT sensor according to the polarity marked in the battery compartment.
Step 2: Insert 2 fresh AAA, Alkaline batteries into the wireless thermometer according to the polarity markings. Step 3: After 5 minutes place sensor outside in a shaded location.
https://www.lacrossetechnology.com/products/WS-9160U-IT#support
Retired unit so no further warranty or parts.
You can still get one on Amazon
La Crosse Technology WS-9160U-IT Digital Thermometer ...
Amazon.ca https://www.amazon.ca > Technology-WS-9160U-Digita...
Digital thermometer with wireless remote and clock; Remote sensor transmits from up to 330 feet; records daily high and low temperatures; Receives weather ...
Rating: 4.4 · ‎ 7,970 reviews · ‎ $31.50 · ‎ In stock
How to switch from centigrade to fareenheit on model TX29U
I believe that would fall under Temp Units during setup.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwj7lMTe77raAhUn8IMKHfU2BzcQFgg2MAE&url=https%3A%2F%2Fwww.lacrossetechnology.com%2Fmedia%2Fcatalog%2Fproduct%2Fw%2Fs%2Fws-9611u-it_manual_011017.pdf&usg=AOvVaw0hODvfW1eUqfE8iy61_KDF
My renault megane remote sensor key doesn't respond when i press it.There is a signal showing red on the dash board which indicates that unless the remote sensor key is press two times,but still i
I would suggest you check the batteries of the remote. If you have replaced them it is possible that the microswitch on the remote might have worn out. Should be a quickfix at a locksmith that has the equipment to test remotes frequency. Good luck
Remote control is not working at all. Checked the remote and replaced battery. Also back sensors not working. only a click while engaging reverse gear. Ford Freestar 2004 limited 4.2 L Is there any...
Hello, I want to try to help you on this problem. The Limited models of the product line have extra "Bells and Whistles" added to the normal dash functions. You have a dash display Computer which shows a Menu for the extra features. On this Menu, you can set the "Back-up" alert system to be On or Off.
Sometimes when an Oil Change is done, the Technicians have to Reset the Oil Change counter. They use this Menu and could easily have changed the settings for the Back-up and the Remote control functions. You need to get into the Menu and see if this is the case.
For added measure if the Menu does not help, look under the Drivers' dash at switch on the Brake pedal(gets bumped), the switch for the Transmission selector is more difficult to see. Test to see If the Back-up sensors work in Neutral and not Reverse, the shift cable will need to be adjusted. That's about all you can do yourself.
Sometimes the "Brain" in the door handle will die and you will need a new part. I hope my solution is very helpful to you.
4helpful
Operating instructions for EM-2R power meter. it has 3 plug-in sender units with remote reader. How do I resynch the senders and reader after replacing battery in reader? Cheers DaveK
I have what appears to be the same device. My instructions list the following method:
1. turn off or disconnect all the remote monitors.
Use the code button on the display module to set the channel. It displays 1 --:-- for channel 1.
Plug in the first remote sensor into the power outlet and press and hold down the SET button until the LED flashes.
The receiver will show numbers where the dashes were in the display.
Change the channel on the receiver to 2 withb the code button, it displays 2 --:--.
Plug in the second remote sensor, press the set button till the LED flashes.
Repeat for channel 3 with the third remote sensor.
This is the same method used to set them up the first time. Having to turn off or unplug the device is the unintuative bit. I assumed it would reconnect after replacing the batteries.
Hi my dash light is showing this (!) and I don't know what it means because it didn't come with a manual can you tell me what this is thanks
isn't the the remote tire pressure sensor. one of the 5 tires....spare included have low pressure or defective..
1helpful
3answers
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Top La Crosse Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
