Hi
One of the two cables is for power to the battery while the other supplies power to the transducer. BOTH cables (+ and -) must be used and intact.
In case anyone requires it, here is the link to the installation manual.
Hope this helps.
-Steve
Lowrance has started using the same power cord on their Elite units and their HDS units. The yellow wire on the power cable is an accessory wake up wire designed to be used in conjunction with the structure scan modules for the HDS.
You can simply tape this wire off during your installation ND ignore it.
The additional wires are for NMEA data transfer to and from other devices and sensors like distance, speed, depth, temperature and NMEA 0183 sentences the unit will use when connected to a VHF radio or other NMEA 0183 device.
Hi Everyone, Has anyone install EP-60R Fuel Sensor unit to Elite 7 HDI ? I have hustle making it work. Appreciate if anyone successfully solve similar problem. Dan
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
