Fisher and Paykel Aquasmart wl80t65c Logo
J
Jerry Ang Posted on Apr 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to start clean me cycle ? - Fisher and Paykel Aquasmart wl80t65c
Peter
Level 2:
Champion:
  • Fisher and P... Expert 203 Answers
  • Posted on May 04, 2016
 Peter
Level 2:
Champion:
Answers
203
Questions
0
Helped
97419
Points
471
Read your user manual. If you don't have one either Google your model number + user manual or phone/e-mail F&P and ask for one.
Nater13
Level 3:
Master:
  • Fisher and P... Master 610 Answers
  • Posted on Apr 25, 2016
Nater13
Level 3:
Master:
Answers
610
Questions
0
Helped
242529
Points
2229
Switch to Powdered Detergent and you wont have to clean your washer. Liquids leave a smelly, corrosive residue on the inside of the machine, use only Powder and leave the lid up when not in use to defeat the slime!
Started clean cycle on rational oven and ran for a bit and clean cycle aborted. and would clear on the screen. How do we reset rational
Use something similar size to the rational pills, place it where you would normally put the pills for cleaning, go to start the cycle, then pop the door before you press start, should trick the rational into unlocking,
Nov 14, 2018 • Ovens
How to get it to do self clean and how long is it suppose to take
Electrolux Self-Cleaning Oven ' Electrolux Kitchen Range ...
? 0:47
https://www.youtube.com/watch?v=JNVPSVe_MV0
Mar 25, 2015 - Uploaded by Universal Appliance and Kitchen Center
Electrolux fresh clean feature is the perfect ingredient for cleaneroven, with 3 different levels of cleaning .
Manually Starting Self Clean cycle on Electrolux Washer
ths.gardenweb.com > Home Forums > Laundry Room
Feb 10, 2011 - So, I want to do a self clean cycle manually. ... wake up washer by pressing any button rotate cycle knob to handwash press start and then cancel. ... I am not sure my machine is operating on the clean cycle.
2helpful
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
How to self clean...no owner manual
Before cleaning, remove the racks and other items in the oven. Clean the oven frame and door frame outside of the gasket with a nonabrasive cleanser like Bon Ami. Wipe up any excess grease or sugary and acidic spills by hand. Turn off the oven light. Ventilate the kitchen well.
Then press the Clean pad once for immediate start. Press Auto Start to increase the cleaning cycle to three hours. Press a second time to get a 4 hour cleaning cycle or three times to return to the two hour cycle. Cleaning and LOC plus the cleaning cycle time will be displayed on the oven. After the cleaning cycle is complete, the Cleaning will no longer be displayed. However, the LOC will remain on until the oven cools down (approximately one hour). You will not be able to open the oven until the LOC message disappears.
Press the Clean Pad twice for a delayed start. Then use the Auto Start button to determine the delay for the cleaning cycle. The rest of the steps will remain the same.
The manual is available from the following site: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JES9800A&siteCd=JA_EN_US&userType=Consumer .
I hope this helps.
(these directions are from the JES9800AAW unit; the above site has the manual for this and the JES9800ACW.)
Kenmore elite dishwasher - setting the default wash
Select the desired cycle. If you want to run the last cycle that
was completed, you can simply press START once to show which
options you used, then press START again to start that same cycle.
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
1helpful
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
1helpful
2answers
Self clean
Usually the oven has to be locked closed with a handle on on the front door. This will activate a safety mechanism that will allow the cleaning cycle to start. If the safety switch is malfunctioning or the door is not closed properly, the cleaning cycle won't start.
Apr 20, 2008 • Ovens
Self cleaning oven will not start for cleaning door lock problem
hi alot of people have been having this same problem with either the door locking before clean cycle and not opening or it goes through clean cycle and then the door is stuck shut and wont open.
You could try this it sometimes works before you press start push the door shut and keep pressure on it i mean lean on the door so your pushing it shut further than it is now then whilst putting pressure on the door try pressing start button again if it then starts cleaning cycle keep pushing door for about a minute then gently let go of the door.
This should then allow it to go through clean cycle but remember when clean cycle has finished dont try opening the door strait away as you will then have the problem door stuck and wont open you need to let the oven cool down before the door will open.
If after pushing the door shut a bit further you still have problem then the only thing you can try is switching off at mains for 24 hours this should release the lock let me know how you get on ok
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
