Panasonic TH-50PX75U Plasma HDTV Logo
Randy Isgro Posted on Apr 25, 2016
TH-50PX75U has no picture just sound
We need to know which board is causing the issue to no picture
4 Related Answers
Chi Chu
  • 8457 Answers
  • Posted on Oct 14, 2009
SOURCE: my tv has no power when turned on th-50px75u
Check the power plug,check the power outlet.Change ur power supply board is dead.
Anonymous
  • 15 Answers
  • Posted on Jul 09, 2010
SOURCE: PICTURE FLICKERS ON & OFF & THEN GOES OUT.
If you have a sound and no picture, especially if it flickers then it rules out the main board and CTRL board being bad. You will want to replace the Y-Main board, but when you replace the y-main board you should always replace the upper and lower ybuffer boards because they can short out your new Y-main board.
Anonymous
  • 1622 Answers
  • Posted on Dec 19, 2010
SOURCE: I have a Panasonic TH-50PX75U Plasma 50" tv. The
All you need to do is to open the back cover of the television to check for burnt transistor , this is always the problem , for you to fix this it require a basic knowledge on electronics,
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help out in solving the problem
Chi Chu
  • 8457 Answers
  • Posted on Feb 05, 2011
SOURCE: I HAVE A PANASONIC TH-50PX75U TV THAT AFTER
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Testimonial: "THANK YOU FOR YOUR INPUT. WE WILL TRY IT. I HOPE THAT WILL BE THE SOLUTION."
I have a panasonic viera th-50px75u and i cant get
Try disconnecting all HDMI cables and plugging the TV into a new wall outlet. If the issue is resolved, it may have been caused by a small power surge from either your wall outlet or one of your source devices.
2helpful
2answers
I HAVE A PANASONIC TH-50PX75U TV THAT AFTER UNPLUGGING AND REPLUGGING THE SET IT WILL NOT TURN ON. THE RED LIGHT IN THE FRONT BLINKS, BUT NO PICTURE OR SOUND. I CHANGED THE BATTERIES IN THE REMOTE BUT IT...
THe red led flashes 10 times and TV does not power on. No picture or sound.
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck, Take care.....
My panasonic 50'is showing a bottom half picture
This is normally caused by the upper scan buffer board.
PICTURE FLICKERS ON & OFF & THEN GOES OUT. SOUND STILL ON. TH-50PX75U PLASMA TURN OFF FOR AWHILE & IT MAY WORK FOR AWHILE BUT WILL START AGAIN.
2answers
My tv has no power when turned on th-50px75u
Picture and Sound Cuts Out When Moved
we repaire lcds 01455848477 cntact us you must have a sort on the powerbourd and give it time it will go
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
