Question about Tru Triple Slowcooker
Middle warmer is corroded, are the other 2 warmers safe to use
  • Tru Master
  • 26,846 Answers
Yes no problem.
Posted on Apr 25, 2016
SOURCE:
My 2003 skidoo summit runs fine but hand warmers don't work and the tach and speedo work intermittent. Any ideas on what to do.
Damaged wiring and/or dirty or corroded wiring connections or switches seems likely.
A wiring diagram would be a help in tracing the circuit of the hand warmers and during the process other problems will probably become obvious. It is easier to start by tracing a permanent fault than intermittent faults.
Jan 07, 2017 | Winter Sports
Sunbeam mattress warmer blinking f2. What should I do.
Play it safe
Check it thoroughly
Any broken internal wires
or is it just the timer
Take it to an Electrician
Cheers Sunbeam mattress warmer YouTube
Mar 14, 2016 | Sunbeam Heating & Cooling
Are chemical hand warmers toxic?
I was also worried about this, but after reading up on the topic, I found that most of the chemicals in these things are safe and non-toxic. No need to worry.
Dec 31, 2012 | Camping, Backpacking & Hiking
Is it safe to put chemical hand warmers elsewhere besides on hands?
Hand warmers usually come with a warning that says they should only be used on hands or feet. Like any product you always have to follow the instructions on the box carefully.
Jul 09, 2012 | Camping, Backpacking & Hiking
Hi my lower part nolonger gets cold enough to keep fresh foods yet the freezer is working well
Set dials to middle setttings, if the colder /warmer dial is peffed max cold its max cold freezer!!! so move to warmer and the freezer will give more airflow to the reefer , the reefer is reliant upon the freezer for its cold air.
Nov 01, 2010 | Magic Chef CTB1821AR Top Freezer...
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
I have a Classic Coffee Concepts GB360 maker that needs switches
I have the same coffee maker which has a heater problem but the wiring is intact. The switches are wired like this:
Right Rear Warmer Switch: Top - White from other two switches
Middle: Black from other switches
Bottom: Red
Right Front Warmer Switch: Top: White shared with other two switches.
Middle: Black with connector to Black on other switches
Bottom: Blue
Lower Front Warmer Switch: Top: White from other switches and connector to white from inside.
Middle: Black and Purple together
Bottom: Black from inside and Purple from inside on a connector.
Jul 07, 2010 | Classic Coffee Concepts SSU50 Stainless...
New Warmrails Towel Warmer Stopped heating
call the company directly at 877-927-6724. Explain the problem and they will assist you or replace your unit.
Jan 10, 2009 | Warmrails & Satin Nickel Towel Warmer &...
Leak
your tank is leaking
Please Follow LINK for parts etc
Jun 12, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Tru Triple Slowcooker Logo
1,371 people viewed this question
Top Tru Water Sport Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Tru Water Sport Expert? Answer questions, earn points and help others
