Garden Logo
F
Felix Posted on Apr 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas edger I need to know how do I repair a broken pull start rope for model 316772380
Broken starting rope
  • Jim Parker
    Jim Parker May 28, 2016
    Hi Felix , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the brand of your machine?
    Jim
Plink-plonk
Level 3:
  • Master 1,807 Answers
  • Posted on May 28, 2016
Plink-plonk
Master
Level 3:
Answers
1807
Questions
Helped
818633
Points
15648
What is the make and model please.?
Have you tried looking on youtube.? there are many helpful videos showing you how to do this on many machines. Try searching '[your make and model] and recoil'
Have a 4 stock troy built weed eater and the pull rope will not retract how cna you fix that
remove pull cover and check spool if sitting flush ,not broken chipped or cracked ,rope not frayed or jammed,turn spool to retract the rope if no resistance spring either broke or popped out of retainer and further disassembly required caution when doing so spring can still have tension the following link shows different type of pull start problems and repairs
Replace Pull Start Cord Yahoo Video Search Results
Jul 14, 2016 • Troy Garden
Lawn edger no compression
check for loose plug
if 2 stroke the rings may be stuck/broken
the sump seals at either end of the crankshaft are faulty
if 4 stroke the valve/ s burnt or stuck open
When asking questions , inclusion of make model year are a big help in getting a more exacting answer.
May 28, 2015 • Garden
Pull start not turning engine. not engaging
www.troybilt.com/equipment/troybilt/ownercenter
Take it off and you will see a pawn(s) that stick out and engages the flywheel when the rope is pulled. You will also see why that is not happening. Stuck ,broken or stripped pawn maybe.
1helpful
Pull start rope is hung up and won't release on my ryobi s430
a broken spring a tangled rope a stuck ingaugement tab
3helpful
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
How to repair a poulan pp 136 trimmer? The rope to start won't rewind.
Most likely you have a broken return spring.whitch will involve removing the blower cover and putting in a new spring,and then reloading the tensionon it.there is trick to that but its hard to explain....you have to tuirn the rope holder the oppisite direction you want it to pull the rope in ,then you feed in the rope while holding the spring loaded then tie the string in and let go...Normally 4-5 rounds will do for a good recoil..Hope it helps
2helpful
Replace the pull rope on a Poulan trimmer
Go to smalleng.com they have video on how to do what you need. Check it out awesome website! The cord you can buy at any local home center. or repair shop.
Jun 07, 2010 • Garden
Does not have any compression! Was running fine, then gradually started slowing down and loosing power and died. Tried to start it and noticed when you pull on starter rope there was no compression.
Sounds like the rings are gone. Either that or the connecting rod has broken. Probably the rings. You can get a replacement part from a local small engine shop. Good luck...Lee
My Brushwacker has a broken pull start rope (model 358.795800). I figure that it shouldn't be too hard to repair it, but I would like to find a manual for repair.
Good luck on finding a manual. You can get the exploded parts drawing off of the sears parts website! I have a 32cc model 358.791580 and the pull rope broke. The pull rope assembly is located inside of the motor housing. I am having trouble removing the clutch assembly since there is no key way or screw holding it to the shaft. Does anyone know if it is threaded on?
1helpful
Hi, I have a Poulan gas blower, the rope will not pull out
remove spark plug for inspection
1) silver or aluminum color
STOP the piston is seezed. TOO costly to repair
2) plug dark brown or black (pretty much normal)
remove recoil housing for tangled rope or broken rope rotor
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Top Garden Experts
Jay Finke
Jay Finke
john h
