SOURCE: BlackBerry 8700g Won't Switch On
please try to conect using active sync. see if it detects anything.
SOURCE: whit screen
Try with the new battery and check it works or not.Otherwise consult hardware vendor for the same.
SOURCE: Screen lit up and turned blank
The following is for the 8000 series Blackberry. This is also providing that your Blackberry does not have a hardware failure:
Some number of months ago, there was a software bullet sent by RIM, via many of the mobile providers to all the 8000 series Blackberries. This was to correct a critical security issue, and some problems with time zones. There were some issues that some of them lost the ability to properly re-start after the update.
The fix is to download the newest Blackberry operating system software and install it. You must get the release that is complient to your provider for some service providers.
To install the updated operating system you can do this with the backup and installation software that is for the Blackberry using the USB cable. DO NOT use Bluetooth to install the new operating system. This will cause a disconnect during the process, and thus it will scrap the Blackberry!
Blackberry FAQ's and download information:
http://www.blackberryforums.com/rim-software/1871-blackberryos-4-x-download-faq-upgrade-downloads.html
It may be best to have the service department for your phone company do the update for you.
Jerry G.
If the touch screen of the Camcorder is not working, please
follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if
that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please
remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15
seconds, turn the Power switch to OFF position and then reinsert the battery
pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
I hope this information will help you to resolve the touch screen issue of the
Camcorder.
