Question about Hotpoint Aquarius WF000 Front Load Washer
Starts to fill then drains with flashing lights and unresponsive buttons
MACHINE STARTS TO FILL, THEN STARTS TO DRAIN, WITH A WHIRING NOISE AND UNRESPONSIVE FLASHIN LIGHTS
SOURCE:
Buffalo12980
  • 625 Answers
SOURCE: hotpoint few12, machine not filling
the timer, electronic or mechanical is not advancing to the fill contact. if mechanical the cam contact may be burnt. if electronic the gated triac [solid state relay] is burned up [replace]
Posted on Sep 06, 2007
vest6
  • 196 Answers
SOURCE: hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Posted on Jan 02, 2008
  • 619 Answers
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
murdozzz2
  • 75 Answers
SOURCE: lights flashing but machine not working
hi there i would check the connections to the heater and ntc both can be found behind the lower inspection cover at the rear, UNPLUG FROM MAINS FIRST AS LIVE PARTS EXPOSSED BEHIND!!!
Posted on Feb 09, 2008
ginko
  • 19396 Answers
SOURCE: HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Posted on Feb 16, 2009
When the dishwasher is turned on it just makes a whirring sound but does nothing. It started making a lot of noise before the cycle finished a few days ago.
The whiring noise is the machine giving itself time to fill with water before it kicks into the next cycle stage, if the machine sensor doesnt detect water within the time set the machine will not go to the next stage and will detect/display a machine fault/error. Can you hear water flow into machine while hearing this noise also? If not This would suggest water intake to machine has been interrupted. if the water flow is not interrupted then with the soap not dissolving it could be either temp thermostate or pump blokage. You'll need your model number to search for the machine Service manual online if you don't still have it. *Do not attempt to clear pump/ diagnose or open your machine without turning machine off and disconnecting plug from the wall*
Jul 02, 2018 | Dishwashers
AEG 40850 - pump noise and running for long time, eventually showing error 20
There is a problem with drainage. Check the drain line connected to the disposal or peatrap. Make sure it is not plugged. Otherwise you can disconnect the drain line and put a wet vac on it to try to clear the hose
May 20, 2016 | AEG Dishwashers
Washing Machine at the start of cycle starts to fill with water for about 5 seconds and then drains starts to fill again and drains as before,after about 10 Mins Machine cycle ends.
Two things to check, maybe the fill hoses are clogged taking too long to fill therefore it begins to drain or you have the drain hose down nthe drain toon far creating a siphon effect!
Jan 11, 2016 | Washing Machines
Can you tell me what nf means
No fill error. The washer thinks it's taking too long to fill up with water
Dec 14, 2014 | Kenmore Elite 45986 Front Load Washer
GE GSLS1100 Spacemaker won't spin or drain. Washes fine then makes a rattleling noise during spincycle.
When I first started using my washer when I hooked up the water it would fill the hose and then stop until I started the machine. Now when I hook up the washer to the faucet water starts to fill the machine before I close the lid and before I start the washing process....? The last time I used the machine it didnt drain and I had a flood, is there a problem with it now???
Jan 09, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Suddenly the spin cycle won't work. The motor makes a funny noise. The drum just remaiins still. Model GWL 11. The lights are on and there is no alarm.
Hi just read your posting.Now, does the machine drain?What lights are on?Does the machine fill with water and agitate?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Funny noise when machine is emptying
service before you have real problems!
Sounds like the coupling connector from the trans. to the agitator is worn and ready to fail.
Bless you
ngafm
Please give me a good rating for my accurate call!
happy to be of service.
Jul 24, 2008 | Estate TAWX700JQ Top Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
44 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
