This mower did this once before.new drive belt fixed problem,but not this time.i am getting tired of removing mower deck. NO PICNIC!!!!!
Roy if it is the correct belt and fairly new, check your manual for belt adjustment, if it shows that there is no adjustment the pulleys may be worn out, on a lot of mowers the pulleys are ware items and changed more often to correct slipping issues. The other thing to check is the belt tensioner if equipped, it could be seized, weak or missing spring or it may even be adjustable by cable end being threaded or slotted bolt holes on tensioner arm.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Drive Pulley Replacement On Craftsman Lawn Tractor
Mower Engine Pulley Replacement Craftsman Riding Lawn Mower Repair Part...
Cub Cadet LT1045 Transmission Drive Belt Replacement
husqvarna LGT24k54 drive belt install
