Buy and sell electronics cars fashion apparel collectibles sporting goods digital cameras baby items coupons and everything else on eBay the world online marketplace
The highest quality lowest priced TV parts DLP lamps TV stands refurbished TVs more 400 000 television parts 300 brands Vizio LG Samsung Sony Philips more Toll free 877 881 6492
They often begin buzzing when the oil inside them gets old or evaporates from a cracked housing. It needs replacing however be very careful. Flyback have 50000 to 100000 volts in them even when the tv is off. There is a safety discharge procedure however if you are not familiar with replacing a flyback do not attempt it yourself. FLYBACK TRANSFORMERS CAN SEVERLY INJURE OR KILL YOU.
The horizontal output transistor that drives the flyback transformer overheats now. There might be other reasons too for this fault. If the flyback transformer has any internal winding short, this transistor will overheat. Just replace the horizontal output transistor. Check its heat. If the newly replaced transistor too overheats, replace the flyback transformer.
the flyback transformer or the Box cap CL031 is arching and will need replacement the flyback is most likley of the two. You can get flyback transformer with instructions from www.tvrepairworld.com
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
When you change the flyback and the HOT you are supose to replace a small capacitor that came with the flyback and also the small coil l401 that connects the hot base to the horiz. driver transformer secondary is supose to be taken out, the leads scrapped off of insulation and resoldered into place.
