Did anyone have this problem ? the machine does make steam, also when i turn it on the coffee group moves freely to the right positions, but the machine doesn't switch to the Coffee Ready display.
This error is because:
1- Flow meter is blocked & not sending signal of water flow.
2- Entire hydraulic system is filled with Calcium deposits and slowed down flow of water.
Solution:
1- Open the machine and manually clean flow meter. It is located between the water tank & the pump.
2- Follow this by manually descaling the machine. Seelink. Do not use automatic descaling method suggested by Jura.
Stop using Filter cartridges as the machine reminders for descaling are silenced by use of filters. Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
SOURCE: No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
SOURCE: Jura Impressa S95
Find a great article on what needs to be done here:
http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
SOURCE: Describe your Jura Capresso Impressa E9 Espresso
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
SOURCE: my jura impressa c9 coffee machine keeps tellnd me
I just called their customer service 800-220-5701 with the same problem.
There's a point at the bottom of the chute where you can add ground coffee that tends to clog, especially if water gets in there. Access is from underneath - - remove the bottom tray and reach in - - it's not the hinged flap opening (that's the first thing you'll feel) but if you leave that closed and reach behind it, there's a silver-dollar sized area you're supposed to try to access and clean using a dry cloth. Once that's done you're supposed to try vacuuming from the top and then let it dry for a day or two.
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
