This Digital Keyboard does not come with a pedal unit. • You can use the PEDAL1 jack to connect an optional (SP-3, SP-20) sustain pedal. You can use the.
They are all compatible. Make sure the port on the keyboard is the same size as the plug on the pedal, usually a phono plug. Also make sure it is a sustain pedal and not an "on off " switch.
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
First, check your volume. Try turning it up the whole way. If that doesn't work, then try moving the slider switch to normal, and playing. Also, try using the keyboard in Song Bank mode. If you have a Sustain Pedal, make sure it's in the accessory port and not the Headphone port. If none of this works, then you may have blown a speaker. Parts are cheap from Casio ($13.00) and are relatively easy to put in yourself.
Yep!!! Happens all the time and only a few synths have the option of selecting the operating mode.
NOW if you can open the pedal, USUALLY the switch has both the Normally Open and Normally Closed functions that a single wire can be moved to reverse the operation.
USUALLY you will need a soldering iron to make the change.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything. If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
