Lands Phones Logo
G
George Williams Posted on Apr 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I turn off the mute function?
2003 model
Art Cacella
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 186 Answers
  • Posted on May 25, 2016
Art Cacella
Expert
Level 2:
Passionate:
Answers
186
Questions
Helped
55423
Points
242
If it is a VTech phone ( CS6429 or similar )
press the [mute] button again: it is a toggle.
First press of [mute] turns mic off (mute-on).
Next press of [mute] turns mic on (mute-off).
Everything works except the volume why
Mute Button
https://www.google.com/search?q=clarion+nx501+mute+button&
NX501E NZ501E
Clarion Global https://www.clarion.com > MungoBlobs > NX501... PDF • Press this button more than 1 second to stop video and audio media. [MUTE] Button. • Mute or Unmute the speaker. • The symbol on upper right area of the ...
123 pages
Switching On, Off Or Mute; Audio Source Selection; ...
ManualsLib https://www.manualslib.com > ... > User manual Press the button again to cancel the mute function. ... by turning off the vehicle ignition and removing the vehicle ignition key. Audio source selection. AM/FM.
NX501A
Clarion Global https://www.clarion.com > NX501A_ENG PDF • Press this button more than 1 second to stop video and audio media. [MUTE] Button. • Mute or Unmute the speaker. • The symbol on upper right area of the ...
138 pages
Functions Of Remote Control Buttons - Clarion Manuals
ManualsLib https://www.manualslib.com > manual > Clarion-Nx501 Functions Of Remote Control Buttons - Clarion NX501 Owner's Manual & Installation Manual ... and audio media. [MUTE] Button. • Mute or Unmute the speaker. • The .
2answers
My Avanti microwave keeps beeping nonstop.
Hi.
To mute your microwave, start by checking the control panel. Look closely. The mute function may be labeled as a secondary function of one of the standard buttons. Check these things first:
  • Look for a Sound button. Seriously. It may have been there all along, begging you to press it.
  • Press and hold either 1 or 0. Sometimes manufacturers give these keys hidden, secondary functions.
  • Press and hold the Stop or Cancel button. Like 1 or 0, this key might have a hidden function when held.
Often, pressing and holding 1, 0, Stop or Cancel will either result in turning off the beeping sounds or activating a child lock feature. (Child lock doesn't actually lock the door, but instead locks the control panel so no buttons can be pressed until the lock is removed by holding the button for around three seconds again.)
If none of these work, it's probably best to consult the manual. Even if you don't have a Sound button, there is no Mute function denoted as a secondary function or holding a button doesn't do anything, there is still a chance a mute function exists. It could be a button combination or, like on some microwaves, be buried in a submenu that's not at all obvious how to activate.
If you've tossed the owner's manual to your microwave, check the manufacturer's website. They will often provide a digital version of the manual as a PDF for more recent models. For an older model, you may need to do some digging, but a great start is to just do a Google search for "[microwave brand and model number] manual."
Once you have the PDF version of the manual, press Ctrl + F on Windows or Command + F on Mac to search the PDF for "mute," "sound" or "beep."
Good luck.
Tv on mute no remote how can I turn mute off
If you have no volume control on the main TV, unplug the TV and then turn it back on. The mute should be cancelled. If you have a volume control, turning it up should cancel the Mute function. It does on mine.
How do I turn off the mute feature on my garmin LMT?
Looks like you can go to the setting and check the volume control. Some models with the + /- button at the side, just keep pushing the + button, the mute function would be off.
Disable mute
should find a mute function key on your keyboard. press and hold the Fn key then tap the function key with the symbol of a speaker on it. eg mine is the F8 key
I pushed a button and lost all sound, what should i do? is there a reset button to get going again?
The "MUTE" function on your remote control has been activated.To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office.
I would like to have my CC come on when I mute the TV?
Most TVs today have a program specifically called the "CC on Mute" function. Go to your "Input Setup Program," also called the "On-Screen Display Menu," and choose from the menu the "Setup" function (usually represented by the image of a "wrench"). If your set is capable of this function, then it ought to be located on this page, so simply choose, turn it on, and you ought to be able to have CC with mute each time you choose to turn it on.
How do u turn the mute off?
Seems that your Pure-Fi Elite had the same problem as mine...sorry for that, but this model does not have a "mute" function. If you bought it before 2 years ago, you are covered by warranty. Remember this model is not avaiable anymore....you will have to choose another U$150 Logitech product. Logitech didn't even asked me to send them my "mute" Pure-Fi Elite...
2answers
Mute button wont turn off
HERE is your manual in PDF format.
This unit doesnt have a volume mute function.
What are the problems you are experiencing.
If it says Mute or ATT on the display - it is the cellular mute function turning off the volume for an incoming call.
Page 34 details turning on and off the cellular mute function.
You also may try a hard reset by removing the face, and pressing the reset button.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
