My Simpson eziload 750 will not shut off the water during cycles when supposed to
All cycles work fine, except when you turn the water on, it's just keeps filling through all the cycles. Usually the machine will stop the water and restart it, when it's needed in the cycle.
Re: My Simpson eziload 750 will not shut off the water...
Start machine as normal. After a few seconds of filling, press the pause button. Water coming in should stop immediately. If it hesitates then stops or does not stop at all you have a faulty inlet valve. Change it.
The timer is that thing you turn & pull out to start a cycle, it then moves around to the finish. The main part of the timer is inside the panel. If it is faulty you will not be able to fix a timer. It will have to be replaced with another timer. New ones can be very expensive. Some are no longer available.
sounds like blocked pump or door latch sensor/switch more likely pump blocked.thats normally first to activate in wash cycle.if unsure seek help to locate and check.it ll be either accessable from bottom front of machine or you may need to tip it up as it ll be at bottom of machine.unplug first,and if you pull pipes off pump to access there will be some water.hold waste pipe as low as itll go to release any water left in machine
1.Turn off machine
2.unplug from power
3.leave unplugged for 5-10 mins
4.open door (if has water in drain via pump/lint filter (botton right flap).
5.empty contents(if wet turn drum by hand( may be unbalanced) close door)
6. turn on power
7. select colours 40 cycle
8. press start button
9.wait a moment ( chip reset )
10.hopefully machine will fill with water and let complete cycle
Hi just read your posting.Depending on how old your machine is it could be a couple of reasons.1st thing I need to know is how old your machine is? Also when the machine should turn the opposite direction listen carefully and do you hear a hum from the motor when it should be turning in the opposite direction?Please reply with this additional information and I am sure I can help you .Looking forward to your reply.
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
