3 STEP WHICH IS PRESS DELETE KEY, SPACE KEY AND SHIFT KEY.
SOURCE: Nokia E90 forgotten lock code
Option No. 1 is
*#7370# is the code to reset everything, including contacts, sms, emails, all application, everything. But you need the 5 digit security code to do this.
Option No. 2
Since you have forgot the lock code, you can try this thing. Using PC Suit, take backup of your phone contents, then update the phone software.
Option No. 3
Unlock Security Code using Memory Card
Steps to unlock ur sec code.
1. Off Ur mobile.
2. remove battry
3. remove memory card
4. On ur computer and plug in ur memory card.
5. insert ur memory card.
6. unzip the attachment file and place it to ur memory card
e:\system\recog
7. now insert ur memory card into ur mobile and switch on the fone.
8. now if it ask for code type 12345 and ur mobile unlocks.
9. Every times u restart ur mobile it will unlock ur mobiles security code.
SOURCE: forgot my lock code for nokia 6275i
Nokia *#7328748263373738# Resets the security code to default(ie,12345)
other solution r
software flashed and reloaded
device replace
check out here
http://www.scribd.com/doc/299040/Nokia-Universal-codes-
