I would like the unlock code for the abovementioned fone plse and instruction on how to do it
I was not able to get a free unlock for the mobile model that you have specified.I suggest you can approach Theunlockspot.com and specify the country,locked network of phone.Based on the availability you can get the permanent unlock service along with free instructions.
Most new Sony will ask for the unlock code when you put a sim in it wont yet accept because it is locked.
Your unlock code is :
CCK: 260704XXXXXXXXXX
NCK: 221877XXXXXXXXXX
NSCK: 40710XXXXXXXXXX
SPCK: 34120XXXXXXXXXX
The letters CCK, NCK, NSCK, SPCK indicate which code to use the different locks on your handset.
So you need to find out which lock is active on the handset ( But usually you'll only need the one marked NCK).
To do this you need to look in a secret menu on the phone
Tap the following in as if you were dialing a number to make phone a call...
*#*#7378423#*#*
A new hidden menu will appear.
Tap on service info
Tap on SIM lock
If you have [x] Network 5 - this means your phone needs the net NCK Code
If you have [x] Service provider 5 - this means your phone needs the SPCK Code
Other Models: 97% Sony Ericsson
1 - Switch ON your phone without SIM Card,
2 - Press 1 time the left arrow,
3 - Press 2 times the button * ,
4 - Press 1 time the left arrow,
5 - The message 'Personalize with MNC2' will appear,
6 - You can now enter the Unlock Code we send to you.
If your phone have a 'JogDial' (ex : Sony Ericsson K700i) you must press 'Down Arrow' instead of 'Left Arrow' for step 2 & 3. We mean by 'Down Arrow' to direct the JogDial down !
W950 models need to use * up * down ** down (up/down using the jog dial on the side).
Satio
Enter # p w + CODE + 1 # into your phone.
Tap repeatedly the star key to get p w + symbols
Older Models
1. Insert a Non accepted SIM card ( EG your new SIM)
2. Switch the phone on
3. Press Left * * Left ( Left is move JogDial stick left )
4. This will open a hidden menu with 4 options (See image)
5. Select 'Network' ( You should see a locked padlock next to the option )
6. Enter the unlocking code we sent you. ( The one marked NCK )
To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use it with a different phone provider, Please click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then this WEB site it provides security codes for a small price.
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
Try this WEB site also - Unlock Free
If you cannot find your model cell phone on these WEB sites, then the security code/restriction code is not available for your cell phone at this stage and hopefully will be available in the near future.
