Question about Hyundai 2007 Sonata GLS
How do I fix my brake lights which are not lighting on my 2007 Hyundai Sonata? I have checked the fuses and bulbs and replaced the brake stop switch but the brake lights still do not work
  • Hyundai Master
  • 1,867 Answers
There was a factory recall for this problem which apparently related to the brake switch. So check with hyundai service on that recall.
See here.....................
Multiple Hyundai recalls for brake lamps and rust issues affect nearly 1M...
Posted on Apr 20, 2016
Testimonial: "Thanks Sean. I had seen this info and the recalls. I had the brake switch replaced as part of the recall back a number of years ago and just tried replacing it again but it did not correct the problem. The bulb looked fine but I ended up replacing it and it solved the issue."
SOURCE:
Hyundai Sonata 2006 v6 brake lights wont work but the rest of the lights work. Also fuses are good and replaced brake switch by pedal and still no brake lights.
Did you ever check to see if power is reaching the bulbs when brake pedal is depressed? Are bulbs properly grounded?
Jun 25, 2017 | Hyundai Cars & Trucks
I have a 2007 Hyundai Sonata and the brake lights (all of them) are not working. I checked the fuse and changed the brake bulbs. Do you have any other suggestions?
Check the following :
1. First of all check the fuse of the brake lamp circuit. use a multimeter to check the +12 volt or use a test lamp of 12 volts.
2. Check the brake lamp pressure switch which is mounted on the master cyclinder- brake pedal. check for connection fault , check for voltage on switch as it must contact when the brake is applied .
3. chek the line to the brake lamp/tail lamp assembly . Check the GROUND connection of the lamp unit, check the holders.
A voltage absence till the lamp end will confirm the area of fault.
Sep 17, 2011 | 2006 Hyundai Sonata
Rear break light will not go on but rear window break light will
could be the light itself,the red brake wire that comes off the rear brake lights that feeds this stop light,sometimes things get shoved against this wire and its cut,or if it splits off in the frame,it could also be broken here too
May 14, 2010 | 2006 Hyundai Sonata
2006 Sonata brake lights don't work except rear deck light.
Check the connection at the brake light switch for power comming out to the barke lights,try feeding power to the brake lights manualy using a jumper wire from your fuse box or battery,unplug the wire from the switch and put power to the harness if everything is OK the brake lights will work,then you need a new switch.
Jul 25, 2009 | 2007 Hyundai Sonata Limited Sedan
Hyundai sonata brake lights
you will probably have to replace the bulb
Jul 07, 2009 | 2007 Hyundai Sonata Limited Sedan
2007 Hyundia Sonata Brake Lights
There was recall for the 2006 and 2007 Hyundai Sonata Brake Light Switch assembly. www.promanuals.net
Apr 27, 2009 | 2006 Hyundai Sonata
My 2006 Hyundai Sonata's brake lights are not working
try the brakelight switch, it is right near the pedal above the footpad
Mar 20, 2009 | 2006 Hyundai Sonata
Brake light inop on 07 Sonata
hi if look at pedal box at where brake pedal is pivoted just above is the brake lights switch with a plug two wires ? unplug then use a wire /paper clip ? and connect the two wire terminals of plug this bypasses switch and lights should come on? if so then remove/unscrew switch fro box and you may find the nylon plunger is stuck in? you can free and lube it so it will come out / in ok then b4 refitting connect the plug and check it operates on and off lights ? ie when out lights on when pushed in lights off
Jan 10, 2009 | 2007 Hyundai Sonata Limited Sedan
2006 Hyundai Sonata brake light problem
there is a tsb for the brake switch in 06 sonatas. it must be adjusted or replaced by dealership. is your check engine light on, if so its probably code p0504
Jun 20, 2008 | 2006 Hyundai Sonata
Hyundai 2007 Sonata GLS Logo
82 people viewed this question
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
moony
Level 1 Expert
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
