RIDGEWAY GRANDFATHER CLOCKS Ridgeway Bennett Curio Cabinet - 8002 Logo
M
MARIA TOLENTINO Posted on Apr 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It wont chime on the hour - RIDGEWAY GRANDFATHER CLOCKS Ridgeway Bennett Curio Cabinet - 8002
deton8 von Splosion
Level 3:
  • Master 3,342 Answers
  • Posted on Apr 20, 2016
deton8 von Splosion
Master
Level 3:
Answers
3342
Questions
6
Helped
928600
Points
54123
Basic assumption... The chimes know what time it is...!!
FORCE NOTHING...!!
From page 10 of owners manual below (MINUTES):
EXAMPLE: Clock chimes at 1:10 but should chime at 1:15.
Step 1: When clock chimes at 1:10 stop the pendulum and record the time of 1:10.
Step 2: Carefully remove the small nut....
(Hour procedure is on the SAME PAGE (10).
WARRANTY INSTRUCTION MANUALS
Reizen Talking Watch. How do I stop my watch announcing every hour please?
Question edited for clarity and toss in some CAPS.
Question moved from Reizen Phone to Resizen Watch.
Hourly Chime Announcement On and Off.
Hourly Announcement (Chime) ON/OFF
(When Chime is ON, the watch announces the HOUR every Hour)
  1. Hold the 8 o'clock button while the watch is in the real time mode for more than 5 seconds until the watch says "Set alarm, Press 10 o'clock button to set."
  2. Push 8 o'clock button 2 more times, until the watch says "Chime ON/OFF, Press 10 o'clock button to set."
  3. Press the 10 o'clock button.
  4. The watch says, "Press 2 o'clock button to turn ON, 4 o'clock button to turn OFF, 8 o'clock button to confirm.
  5. To turn OFF a Chime Alert, Press 4 o'clock button. To turn ON a Chime Alert, Press 2 o'clock button.
  6. Press 8 o'clock button to confirm.
  7. After a Chime alert is turned ON, the watch will announce the HOUR every one hour.
Reizen Analog Talking Watch Instructions
Amazon Web Services https://bf-website-uploads-production.s3.amazonaws.com > ...
When the chime is turned "on", the watch announces the time every hour, around the clock, or 24 times per day, every day. This feature uses a lot of battery ...
TALKING ATOMIC WATCH INSTRUCTIONS
Independent Living Aids https://independentliving.com > content > 7565...
Hourly Announcement (Chime) ON/OFF Push 8 o'clock button 2 more times, until the watch says "Chine ON/OFF, Press 10 o'clock button to set." Press the 10 o' ...
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
Hour chime randomly chimes 60 or 70 times
A worn chime cog wheel will not reset or advance the count. Unless you're good at making gears, you'll need a decent clock repair guy in your area.
Feb 08, 2019 • Chime Home
Our clock chimes 3 hours ahead, if it is 7 o'clock, it chimes 10 times. we have tried all the fixes in the owners manual and nothing is working.
With our old clock when the chimes got off, we would advance the clock hands 3 hours while NOT allowing the clock to chime any of the hours or half-hours.
Jul 17, 2017 • Home
After spot cleaning mantle clock with German movement (circa 1960), the clock chimes properly on the hour but does not chime on the half hour.
I am hoping that you oiled it also? One trick I have found is to gently lift the hammers and release, sometimes the hammers will release and strike the chimes/gong. Do this 4-5 times and hopefully it will get it chiming for you again.
UsedClockParts.com
Nov 09, 2016 • Home
1helpful
NEED DIRECTIONS FOR CHIME
clocks chime the hour
what is the point of having a clock that chimes every 2 hours because you will not know how long it was from the last chime or be able to calculate the time between chimes
Dec 28, 2015 • Watches
2helpful
How do I get it to chime on every hour
most chiming clocks only chime on the hour from 6 am to 9 pm
if it is a digital clock with a chimer the set it to 12 hour and not 24 hour
make sure that the chime has a good battery in the chime circuit and it is set to chime on the correct hour
If the statement made to you was correct then it would be chiming at night instead of the day
Oct 13, 2015 • Home
My Gazo GF Clock won't chime on hour at all
When you are setting your clock, when you go pass the hour you have to let the clock chime completely, if you do not do this you can damage the time sequence..You have to reset the chime cable or belt...but anytime you set your clock when you get to hour let it chime completely before continuing on...Try also going around with hour hand onetime and let it chime, if it will chime at all, if not you can get a manual download online. Clocks like yours has websites and support who can help you...I think it just needs the chimes reset.
Dec 17, 2014 • Home
4helpful
2answers
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 • Watches
Top RIDGEWAY GRANDFATHER CLOCKS Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a RIDGEWAY GRANDFATHER CLOCKS Furniture Expert? Answer questions, earn points and help others
