Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
SOURCE: I have a cub cadet Zero turn mower Z50 and when I
On the transmissions, there are bypass levers...make sure they are pushed in and not pulled out
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
SOURCE: My daughter gave me her old Cub Cadet model 2145
linkage is connected correct? Did it work prior correct? Did you prurge after changing fluid
Testimonial: "Well you were exactly right. I had to remove the two plugs on top and kept operating the lever until I got the oil to run out the top. Runs great."
SOURCE: PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
SOURCE: toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
